node-red-contrib-telegrambot-home 0.8.0
Useful nodes for connecting your home to Telegram
npm install node-red-contrib-telegrambot-home
Useful nodes for connecting your home to Telegram.
Getting Started
This assumes you have node-red already installed and working.
sudo service nodered restart
Telegram Bot Setup
You will need to setup a Telegram bot in order to use these nodes. You can follow these instructions for how to do it. In summary:
  1. Create the bot: Send BotFather the message /newbot
  2. Name the bot: Give it any name. This is how you will see it in Telegram.
  3. Give the bot a username: Must be unique. Doesn't have to match the bot's name.
  4. Grab the token: You will need this for configuring the nodes.
  5. Send the bot a message: Just say hi or click the start button in the chat window.
  6. Grab the chat ID: curl "https://api.telegram.org/bot${TOKEN}/getUpdates" replacing ${TOKEN} with your bot token.
You will get a JSON response like the following:
{"ok":true,"result":[{"update_id":123456,
"message":{"message_id":1,"from":{"id":123,"is_bot":false,"first_name":"Your","last_name":"Name","language_code":"en-US"},"chat":{"id":987654321,"first_name":"Your","last_name":"Name","type":"private"},"date":12345678,"text":"/start"}}]}
In this example, the chat ID is 987654321.
If you get an empty response, try sending the bot another message. If it's still empty, make sure the bot is not in use by another application (or node) as it will consume the message before you can grab the ID.
If you wish to send messages to multiple chats, you will need to repeat the steps for grabbing each individual chat ID. Sending messages to a group has not been tested, but should be similar to the above steps.
You can then use the token and chat ID to configure the nodes.
Included Nodes
You can view detailed documentation for the nodes via the node-red info pane. Just select a node and start readin'.
switch
Route messages based on a response from a user via Telegram
Example
notify
Send a notification to a user via Telegram
Example
payload
Send an arbitrary payload via any available method to a user via Telegram
All of the Telegram API methods are available to you, either through the node properties or via dynamic payload generation.
Static
Example
Dynamic
Example
command
Initiate a flow based on a command said in the chat
Example
Command nodes can also be configured for multi-chat flows. All other nodes are compatible and will route the message to the originating chat automatically. Simply leave the chat ID blank on the other nodes to enable this feature (and ensure the other chat IDs are authorized).
Development
An environment with node-red can be easily spun up using Docker and Docker Compose.
  1. Clone this repository: git clone https://github.com/scraton/node-red-contrib-telegrambot-home
  2. Install node dependencies: cd node-red-contrib-telegrambot-home && yarn install
  3. Start the docker environment: yarn run dev
Credits
Gotta give credit where credit is due.
Version: 0.8.0
Updated 3 years, 9 months ago
Rating: 4.3 7
160 in the last week
  • telegrambot-config
  • telegrambot-command
  • telegrambot-switch
  • telegrambot-notify
  • telegrambot-payload
  • telegram
  • bot
