node-red-contrib-techulus-push 1.0.0
A Techulus Push API wrapper for Node-RED
A Node-RED node to send notifications via Techulus Push.
Run the following command in the root directory of your Node-RED instance,
typically ~/.node-red.
npm install --save node-red-contrib-techulus-push
Uses Techulus Push to send msg.payload to all the devices registered in
your account.
- Uses
msg.topicto set the title, if not already set in the properties. - Optionally uses
msg.linkto set the link, if not already set in the properties.
Copy your API key from your Techulus Push dashboard to the API Key
field in the node properties.
References
- REST API Reference: https://docs.push.techulus.com/api-documentation
