node-red-contrib-teamogy-email 0.0.3
Node-RED node for sending emails via SMTP using nodemailer
npm install node-red-contrib-teamogy-email
SMTP node for Node-RED
Connect to SMTP server and send emails.
You must configure the Connection before using this node.
Connection Configuration
Parameter Type Required Description
Name string Optional A name for the connection (auto-generated if not provided)
Server string Required Hostname of server or IP address
Port number Required Port number to connect
TLS checkbox Optional If checked, the connection will use TLS when connecting to the server. If unchecked (default), then TLS is used if the server supports the STARTTLS extension. In most cases, set this value to checked if you are connecting to port 465. For port 587 or 25, leave the value unchecked
User string Required Username
Password string Required User's password
Input Message Format
Due to backward compatibility with other nodes, it is possible to send parameter values in the input message in several ways described below. The first parameter value is always used in the order listed, and individual ways can be combined in one input message.
Required Fields
Parameter Type Available Properties Description
From string msg.from, msg.payload.from, msg.email.from Email address of the sender
To string msg.to, msg.payload.to, msg.email.to Email address of recipient(s), multiple recipients separated by a comma
Subject string msg.subject, msg.payload.subject, msg.email.subject, msg.topic Text of subject (Unicode string)
Optional Fields
CC string msg.cc, msg.payload.cc, msg.email.cc Carbon copy recipients, multiple addresses separated by a comma
BCC string msg.bcc, msg.payload.bcc, msg.email.bcc Blind carbon copy recipients, multiple addresses separated by a comma
Reply-To string msg.replyTo, msg.payload.replyTo, msg.email.replyTo Reply-to address(es), multiple addresses separated by a comma
Text string msg.text, msg.payload.text, msg.email.text Email body in plaintext (Unicode string)
HTML string msg.html, msg.payload.html, msg.email.html, msg.payload Email body in HTML format (Unicode string)
Note: HTML content takes precedence over Text content when both are provided.
Attachments can be added using msg.attachments, msg.payload.attachments, or msg.email.attachments as an array of objects.
Examples:
attachments: [
  {   // utf-8 string as an attachment
    filename: 'text1.txt',
    content: 'file content text'
  {   // binary buffer as an attachment
    filename: 'text2.txt',
    content: new Buffer('file content text', 'utf-8')
  {   // file on disk as an attachment
    filename: 'text3.txt',
    path: '/path/to/file.txt' // stream this file
  {   // filename and content type is derived from path
  {   // stream as an attachment
    filename: 'text4.txt',
    content: fs.createReadStream('file.txt')
  {   // define custom content type for the attachment
    filename: 'text.bin',
    content: 'file content text',
    contentType: 'text/plain'
  {   // use URL as an attachment
    filename: 'license.txt',
    path: 'https://readme.teamogy.com/docs/licence'
  {   // encoded string as an attachment
    content: 'VGVhbW9neSBGbG93',
    encoding: 'base64'
  {   // data uri as an attachment
    path: 'data:text/plain;base64,VGVhbW9neSBGbG93'
  {   // use pregenerated MIME node
    raw: 'Content-Type: text/plain\r\n' +
    'Content-Disposition: attachment;\r\n' +
    '\r\n' +
    'file content text'
Output Message
Parameter Type Description
payload string | object The standard output or error of the response
References
Version: 0.0.3
Updated 4 months, 1 week ago
173 in the last week
  • email-config
  • email-client
  • teamogy
  • email
  • smtp
  • nodemailer
