node-red-contrib-teamogy-api 0.0.35
Node for connecting to the Teamogy API.
npm install node-red-contrib-teamogy-api
Teamogy API Node
Connection Configuration
You must configure a Connection before using this node.
Parameter Type Required Description
Name string Optional You can enter a name or it will be generated on first save
Subdomain string Required Enter the name of the subdomain and the domain, in the format: subdomain.domain.com
Unit/Agency number Required Enter the number of unit or agency
Token string Required Enter the generated API token for the given subdomain and Unit/Agency
Req/min number Required Enter the maximum number of API requests per minute for the given subdomain, if the limit is greater than allowed, further requests will be rejected (not processed)
Input
Name string Optional You can enter a name for the given node (recommended)
Connection selection - list Required Select the configured connection
Request views checkbox - yes/no Required Check for requests for API views (see description below)
Token selection - list Required Select the desired entity
Req/min selection - list Required Select an available method
Source selection - list Required The parameters or even the request body can be static, i.e. from the Params and Body fields in the form, or dynamic as part of the input message
Source of body string Required The parameter set the source of the body, default is msg.payload
Params string | object Optional You can enter the params in the case of a static request as a string, in the case of a dynamic also as an object, according to the API specification for the given entity
Body JSON string | object Optional You can enter the body in the case of a static request as a JSON string, in the case of a dynamic also as an object, you can nest objects and arrays in the body without restrictions according to the API specification for the given entity
Merge checkbox - yes/no Optional Check if you want the output message to contain all returned records. In the background, processing is still taking place according to the Paging settings, but individual messages are not sent to the output, but only the final merged one containing all the returned records. (if not specified the value no is used)
Limit number Optional Limitation of the total number of records in the response (if not specified, the value 0 is used, the value 0 means no limit)
Paging number Optional Division of responses into multiple parts with the number of records returned (if not specified, the value 1000 is used)
Offset number Optional Determining from which records to return, e.g. if you have a total of 100 records and want to return records 50-100, set Offset to 50, if you want to return all records leave the option at 0 (if not specified, the value 0 is used)
Delay number Optional Specifies the delay between requests, which is used for pagination (if not specified, the value 0 is used)
Req. repeat number Optional Specifies the number of errors after which the request will be repeated (if not specified, the value 5 is used)
Req. delay (s) number Optional Specifies the delay between requests, which is used when retrying a request in case of an error (if not specified, the value 30 is used)
Skip boolean Optional, in message only Adding the msg.skip=true will allow the message to pass through to the output without processing
Connection string Optional, in message only Replaces connection from configuration, use connection name
Unit number Optional, in message only Replaces unit from connection configuration, use unit/agency id
Entity string Optional, in message only Replaces entity from configuration, use v_entityName for views or r_entityName
Method string Optional, in message only Replaces method from configuration, use the available method for the given entity
Examples
Static Request Examples
Enter the desired values according to the selected entity and method in the Params field. Values for Params are listed on separate lines:
id=3
registration=12345678
For API views:
columns=firstName,lastName
externalFilter=id>5
For Body field (JSON):
  "id": 3,
  "registration": 12345678
Dynamic Request Examples
For API views, as string:
id=2&name=John
Or as an object:
msg.params.id = 2
msg.params.name = "John"
For Body, as JSON string:
{"id": 3, "name": "John"}
Or as an object:
msg.body.id = 2
msg.body.name = "John"
msg.body.address = addresses // array of objects
Output
Property Type Description
payload string | object The standard output of the response
count number Number of records in the output
error string Error message
msg.* string | object All properties of the input message
References
  • Teamogy Flow docs - full description of Teamogy Flow
  • Teamogy API docs - full description of parameters for msg.params and msg.body properties, and also options for API views
Version: 0.0.35
Updated 3 weeks, 1 day ago
Rating: 5.0 3
16 in the last week
  • teamogy-config
  • teamogy-client
  • teamogy
  • api
