node-red-contrib-teachable-machine-cloudonly 1.0.4
Simplifies integration with Teachable Machine models from Google
npm install node-red-contrib-teachable-machine-cloudonly
Version Repo
1.3.1 Origin: https://github.com/bonastreyair/node-red-contrib-teachable-machine
1.0.0 THIS FORKED REPO
This repository was forked from version 1.3.1 of the original repository. This is a workaround for a bug in the latest version of the original when installed on Node-RED running on virtualized PaaS (e.g. Railway, Render). Therefore, as the name "cloudonly" implies, it does not support loading model files that are locally located and will not be supported in the future.
You have two options to install the node.
  • Use Manage palette option in Node-RED Menu (recommended) manage_pallete
  • Run the following command in your Node-RED user directory - typically ~/.node-red
Note: If you run the command you will need to restart Node-RED after installation. If installation goes wrong please open a new issue.
Node usage
Step 1
Go to Teachable Machine and follow the steps to train your custom classification model. Once trained click on the Export Model button.
teachable_machine_export
Step 2
Select Tensorflow.js format and upload your trained model (for free). Once it is uploaded, copy the generated URL.
use_teachable_machine
Step 3
Paste the saved URL into the node configuration. That URL hosts all the information to load your trained model. Make sure you copy all the given URL including the https://....
config
Step 4
In Node-RED send a buffered image (jpeg or png) to the node. Check the example in the Import section.
Node Status Information
Shape
  • ■ dot: node is idle
  • □ ring: node is working
Color
  • 🟩 green: model is available
  • 🟨 yellow: preparing model
  • 🟥 red: node error
Requirements
  • Node-RED v2.0.0+
  • Node.js v12.20.0+
Note: MacOSX, Windows 10 and Ubuntu 18.04+ are supported as well as using official docker nodered/node-red image based on Alpine image. Works with Raspberry Pi too since release v1.2.0+.
Mentions
Version: 1.0.4
Updated 3 years, 7 months ago
15 in the last week
  • teachable machine (cloudonly)
  • tensorflow
  • tensorflowjs
  • classification
  • teachable machine
  • google
