node-red-contrib-teachable-machine 1.4.1
Simplifies integration with Teachable Machine models from Google
npm install node-red-contrib-teachable-machine
Node-RED node pre-commit.ci status CI npm latest release npm total downloads Package Quality JavaScript Style Guide Code Climate maintainability GitHub license donate PayPal
A Node-RED node based in tensorflow.js that enables to run custom image classification trained models using Teachable Machine tool. All notable changes to this project will be documented in the CHANGELOG.md file.
You have two options to install the node.
  • Use Manage palette option in Node-RED Menu (recommended) manage_pallete
  • Run the following command in your Node-RED user directory - typically ~/.node-red
Note: If you run the command you will need to restart Node-RED after installation. If installation goes wrong please open a new issue.
Node usage
Step 1
Go to Teachable Machine and follow the steps to train your custom classification model. Once trained click on the Export Model button.
teachable_machine_export
Step 2
Select Tensorflow.js format and upload your trained model (for free). Once it is uploaded, copy the generated URL.
use_teachable_machine
Once the URL is generated it will show the stored files.
model_files
Step 3
Online Mode
Select Online Mode and paste the saved URL in the node configuration. That URL hosts all the information to load your trained model. Make sure you copy all the given URL including the https://... and the / in the end.
online-config
Local Mode
Download all three files from the generated URL and save them locally in a folder maintaning the original filenames.
Select Local Mode and write down the absolute path of the folder that contain the three downloaded files in the node configuration. Make sure it ends with a / noting it is a folder.
local-config
Step 4
In Node-RED send a buffered image (jpeg or png) to the node. Check the example in the Import section.
Node Status Information
Shape
  • ■ dot: node is idle
  • □ ring: node is working
Color
  • 🟩 green: model is available
  • 🟨 yellow: preparing model
  • 🟥 red: node error
Requirements
  • Node-RED v2.1.0+
  • Node.js v16.20.0+
Warning: Only the official Docker nodered/node-red image based on Debian v3.1.0+ image works since it needs ld-linux-x86-64.so.2. This necessary library is not present in the default Alpine Docker image version.
Version: 1.4.1
Updated 3 years, 5 months ago
Rating: 4.6 10
114 in the last week
  • teachable machine
  • tensorflow
  • tensorflowjs
  • classification
  • teachable machine
  • google
