node-red-contrib-tcc-honeywell 0.0.1
Node for interfacing with legacy (my total connect comfort/TCC) Honeywell thermostats in Node-Red
Interface for Honeywell Legacy Thermostats Node for Node-Red. Pulls data from the Honeywell TCC (Total Connect Comfort) API, which appears to be mostly undocumented now.
Project status: presently testing the ability to send data. Getting the status works fine and changng settings seems to properly connect tot he API and return data, but I have had issues with the cahnges actually being reflected on my thermostat. Settings are limited to data that can be sent to the api body. Since the api is undocumented, the only things I've found are turning the termostat on and off, setting a hold temperature, changing the running mode (heat, cool, etc.), and setting a hold time.
From other sources (referenced below), the commands that the (undocumented) api seems to accept are:
SystemSwitch0 = emergency heat; 1 = heat; 2 = coolHeatSetpointtemperature to set the heat toCoolSetpointtemperature to set the a/c toHeatNextPeriodtime to end hold and go back to next scheduled actionCoolNextPeriodtime to end hold and go back to next scheduled actionStatusHeat1 for hold, 0 for regular (set to 0 to cancel an existing hold)StatusCool1 for hold, 0 for regular (set to 0 to cancel an existing hold)FanMode0 = auto; 1 = on
In node-red, for a node input, to change a setting, msg.payload is expected to be an object (or JSON) containing the settings to send in the request to the thermostat. For example, to set the cool setpoint until a time: msg.payload could be { CoolNextPeriod: 12345, CoolSetpoint: 74, StatusCool: 1 }. If msg.payload is instead the string "status" - or if it is any string or anything other than JSON or an object - the node will simply request the status from the thermostat and return the result. Results are output as an object, but can be converted to JSON.
Some Useful References:
