node-red-contrib-tb-device-controller 3.3.3
Node-RED node for tb-device-controller
npm install node-red-contrib-tb-device-controller
ThingsBoard open-source IoT platform REST API Device Controller.
To install the stable version use the Menu - Manage palette - Install option and search for node-red-contrib-tb-device-controller, or run the following command in your Node-RED user directory, typically ~/.node-red
Methods
POST /api/device/bulk_import
There's an ability to import the bulk of devices using the only .csv file.
Available for users with 'TENANT_ADMIN' authority.
body :
Accept : 'application/json'
Content-Type : 'application/json'
POST /api/device/credentials
During device creation, platform generates random 'ACCESS_TOKEN' credentials. Use this method to update the device credentials. First use 'getDeviceCredentialsByDeviceId' to get the credentials id and value. Then use current method to update the credentials type and value. It is not possible to create multiple device credentials for the same device. The structure of device credentials id and value is simple for the 'ACCESS_TOKEN' but is much more complex for the 'MQTT_BASIC' or 'LWM2M_CREDENTIALS'.
body :
GET /api/device/info/{deviceId}
Fetch the Device Info object based on the provided Device Id. If the user has the authority of 'Tenant Administrator', the server checks that the device is owned by the same tenant. If the user has the authority of 'Customer User', the server checks that the device is assigned to the same customer. Device Info is an extension of the default Device object that contains information about the assigned customer name and device profile name.
Available for users with 'TENANT_ADMIN' or 'CUSTOMER_USER' authority.
deviceId : string
GET /api/device/types
Returns a set of unique device profile names based on devices that are either owned by the tenant or assigned to the customer which user is performing the request.
GET /api/device/{deviceId}
Fetch the Device object based on the provided Device Id. If the user has the authority of 'TENANT_ADMIN', the server checks that the device is owned by the same tenant. If the user has the authority of 'CUSTOMER_USER', the server checks that the device is assigned to the same customer.
deviceId : string
DELETE /api/device/{deviceId}
Deletes the device, it's credentials and all the relations (from and to the device). Referencing non-existing device Id will cause an error.
deviceId : string
GET /api/device/{deviceId}/credentials
If during device creation there wasn't specified any credentials, platform generates random 'ACCESS_TOKEN' credentials.
deviceId : string
POST /api/devices
Returns all devices that are related to the specific entity. The entity id, relation type, device types, depth of the search, and other query parameters defined using complex 'DeviceSearchQuery' object. See 'Model' tab of the Parameters for more info.
body :
Apache License Version 2.0
https://github.com/thingsboard/thingsboard/blob/master/LICENSE
Version: 3.3.3
Updated 5 years ago
License: Apache License Version 2.0
1 in the last week
  • tb-device-controller
  • tb-device-controller-service
  • thingsboard
  • device-api
