node-red-contrib-tapo-p125m 0.1.6
Node-RED nodes for TP-Link Tapo P125M smart plug
npm install node-red-contrib-tapo-p125m
Node-RED nodes for reliable local LAN control of the TP-Link Tapo P125M smart plug using tp-link-tapo-connect.
Why
Some existing Tapo Node-RED nodes can read status but fail to toggle the P125M reliably.
This module provides explicit ON, OFF, and STATUS nodes with a shared configuration node.
From the Node-RED Palette Manager, search for:
Or install manually:
Restart Node-RED after installation.
Config node: tapo-device
Stores:
  • Device IP address
  • Credentials (stored securely in Node-RED credential storage)
    OR credentials via environment variables
Action nodes (category: Tapo P125M)
  • P125M on
  • P125M off
  • P125M status
All action nodes reference a tapo-device configuration node.
Credentials
Option A: Node-RED credential storage (recommended)
Enter Email/Password in the tapo-device config node.
Credentials are stored in flows_cred.json and are not included in exported flows.
Recommended setting in ~/.node-red/settings.js:
credentialSecret: "your-long-random-string"
Option B: Environment variables
Enable Use env vars in the tapo-device config node and define:
export TAPO_EMAIL="[email protected]"
export TAPO_PASSWORD="yourpassword"
Example output
Success:
  "ok": true,
  "cmd": "on",
  "ip": "192.168.1.11",
  "device_on": true,
  "model": "P125M"
Error:
  "ok": false,
  "cmd": "off",
  "error": "Missing credentials in tapo-device (or env vars)."
Example flow
See examples/example-flow.json in the repository.
Compatibility
  • Node-RED >= 3.x
  • Node.js >= 18
  • TP-Link Tapo P125M
MIT
Version: 0.1.6
Updated 10 months, 2 weeks ago
367 in the last week
  • tapo-device
  • tapo
  • tplink
  • p125m
