node-red-contrib-tapo-new-api 0.5.4
Unofficial node-RED node for connecting to TP-Link Tapo devices with new API. Currently limited to the P100 & P105 & P110 smart plugs and L510E smart bulbs.
npm install node-red-contrib-tapo-new-api
Unofficial node-RED node for connecting to TP-Link Tapo devices with new interface (KLAP) and previous one (PASSTHROUGH). Currently limited to the:
  • P100, P105, P110, P115 smart plugs
  • L510E, L530E smart bulbs
  • L900-10 smart strip
Node command options
  • power
    This node command provides the ability to power (on / off) the device by input "msg.payload" (boolean)
  • toggle
    This node command provides the ability to toggle (on / off) the power of tapo smart plugs.
  • turn-on
    This node command provides the ability to power on tapo smart plugs.
  • turn-off
    This node command provides the ability to power off tapo smart plugs.
  • brightness
    This node command provides the ability to set the brightness of tapo smart bulbs.
  • color
    This node command provides the ability to set the color of tapo smart bulbs.
  • status
    This node command provides the ability to get the device infomation of tapo smart plugs. Models that can monitor energy acquire energy information.
    "output: msg.payload.tapoDeviceInfo, msg.payload?.tapoEnergyUsage(P110 only)" will provide the device information and usage (if device can measure energy).
  • components
    This node command provides the ability to get the device components information.
  • command
    This node command provides the ability to set a customized request to the device by input "msg.payload" (TapoRequest object):
    {"method": string, "params": {"key": value, ...}} should be provided as valid request.
Node configuration by message (msg)
You can always override the node command configuration by means of the following message properties:
  • "msg.config.command" takes an string with one of the following valid command options
    type command_type = "status" | "power" | "on" | "off" | "toggle" | "color" | "brightness" | "components" | "command";
  • "msg.config.version" takes a number indicating the protocol
    (1 - PASSTHROUGH, 2 - KLAP, 3 - AUTO)
  • "msg.config.verbose" takes a boolean indicating the error verbose.
    When verbose is selected a "msg.payload.errorInf.track" object is included.
  • "msg.config.terninal_random" takes a boolean indicating the terminal to use.
    When terminal_random is true a random terminal valid UUID is used (useful when various buttons are configured to attack same device).
Pre-requisites
The node-red-contrib-tapo-new-api requires Node.js v15.0.0 or higher to be installed.
  • Properties
    config
    • Name
      Set the node name displayed in the flow.
    • Email
      Set the email address registered with Tp Link.
    • Password
      Set the password registered with Tp Link.
    • Protocol
      Set the protocol to be used in the communication with Tapo device.
    • Command
      Set the kind of command the node will take as initial configuration.
    • Search mode
      Select a search mode for the tapo device.
      • ip : search by ip. (It's fast.)
      • alias: search by alias and ip range.
    • Tapo ipaddress(selected: ip)
      Set the IP address to the Tapo device.
    • Tapo alias(selected: alias)
      Set the tapo device alias registered with Tp Link.
    • Tapo find ip range(selected: alias)
      Set the IP range to search for Tapo device.
      • case1: "192.168.0.1 to 192.168.0.25"
      • case2: "192.168.0.0/24"
Inputs
msg
type search_mode_type = "ip" | "alias";
type config {
    email: string;
    password: string;
    deviceIp: string;
    deviceAlias: string;
    deviceIpRange: string;
    searchMode : search_mode_type;
    command?: command_type; /* Default: "status" */
    version?: TapoProtocolType; /* Default: AUTO */
    verbose?: boolean; /* Default: false */
    terminal_random?: boolean; /* Default: false */
type payload: boolean /* power */ || string /* color */ || number /* brightness */ || TapoRequest /* command */
[example1]
msg.config = {
  "email": "[email protected]",
  "password": "password",
  "deviceIp": "192.168.0.xxx",
  "command": "power",
  "version": 3 /* AUTO */
msg.paylaod = true;
[example2]
msg.config = {
  "command": "toggle",
  "version": 2, /* KLAP */
  "verbose": true
[example3]
msg.config = {
  "command": "color"
msg.paylaod = "white";
Outputs
The processing result is passed by msg.payload. It consists of an object that contains the following properties:
type TapoResuls = {
    result: boolean; /* true: success, false: failure */
    tapoDeviceInfo?: TapoDeviceInfo; /* Tapo device infomation */
    tapoEnergyUsage?: TapoDeviceInfo | undefined; /* Tapo device energy if compatible */
    tapoComponents?: Components | undefined; /* Tapo device components information */
    tapoCommand?: Json_T | undefined; /* Tapo device results from "command" */
    errorInf?: Error;
[smart plug device infomation]
You can tell if the device is on or off by getting "device_on".
true: smart plug power on
false: smart plug power off
    result: true,
    tapoDeviceInfo: {
      device_id: "*************"
      fw_ver: "1.2.10 Build 20200609 Rel. 33394"
      hw_ver: "1.0.0"
      type: "SMART.TAPOPLUG"
      model: "P105"
      mac: "XX-XX-XX-XX-XX-XX"
      hw_id: "*************"
      fw_id: "*************"
      oem_id: "*************"
      specs: "JP"
      device_on: false
      on_time: 0
      overheated: false
      nickname: "3d printer power supply"
      avatar: "plug"
      time_usage_today: 0
      time_usage_past7: 0
      time_usage_past30: 0
      longitude: 0
      latitude: 0
      has_set_location_info: true
      ip: "192.168.0.XXX"
      ssid: "SSID"
      signal_level: 0
      rssi: 0
      region: "Europe/Madrid"
      time_diff: 0
      lang: "es_ES"
    tapoEnergyUsage: {
npm-scripts
There are some npm-scripts to help developments.
  • npm install - Install the testing environment in your project.
  • npm run build - Make ./data/my-node directory from the src directory and Install the my-node in Node-RED.
  • npm run start - Start Node-RED. "http://localhost:1880"
File tree
[root]
│  package.json
│  README.md
│  tsconfig.json
├─data -> `Node-Red work files`
│  ├─my-node -> `project files` The resource files and built files should be placed here.
│  │  │  package.json
│  │  └─nodes -> The resource files and built files should be placed here.
│  └─node_modules
├─dist -> `The project built files`
├─examples -> `node-RED flow files`
├─figs
└─src
    └─nodes -> project files
        ├─icons
        ├─lib
        ├─locales
        │  ├─en-US
        │  └─es-ES
        └─test
Version: 0.5.4
Updated 2 years, 4 months ago
License: Apache
Rating: 5.0 7
65 in the last week
  • tplink
  • p100
  • p105
  • p110
  • p115
  • L510E
  • klap
  • passthrough
