node-red-contrib-taiponrock-kg 1.0.1
test node
npm install node-red-contrib-taiponrock-kg
Overview
This node is a node for forcibly converting all the alphabet character strings passed as input to the character string "Taipon rock".
Even if the input parameter passed is not a character string, "Taiponrock" is forcibly returned.
In this process, it is a wonderful node that changed the sample node that was executing toLowerCase, which is an instance method of String object in JavaScript, to a process that just returns a meaningless constant.
how to use
It is used when you want to forcibly convert all the character strings of the parameters to be passed to "Taiponrock".
Version: 1.0.1
Updated 1 year, 1 month ago
  • taiponrock
  • taiponrock
