node-red-contrib-tail-file 1.2.6
Tail for file (Windows, Linux etc)
npm install node-red-contrib-tail-file
Node-RED Node: Tail for file beta
Developed for Windows, but should work on other systems too.
Feedbacks are welcome.
From Node-RED:
Menu - Manage palette - Install - type "node-red-contrib-tail-file"
Install with npm:
(Linux) cd cd ~/.node-red
(Windows) cd c:\Users\<USER>\.node-red\
Dependencies
paulmillr/chokidar (tested on v2.0.4)
jprichardson/node-fs-extra
Options
Mode: Rewritable file
Use this for files which are fully rewritable each time. With parameter lineBytes (default: 512) node will remember last 512 bytes of current file and try to find them in new file. You can limit size with options limitSize and maxBytes ("Maximum in one read" option).
If you got many errors try to increase interval ("Interval" option). This is equivalent of chowkidar's parameter stabilityThreshold.
From chokidar description:
By default, the add event will fire when a file first appears on disk, before the entire file has been written. Furthermore, in some cases some change events will be emitted while the file is being written. In some cases, especially when watching for large files there will be a need to wait for the write operation to finish before responding to a file creation or modification. Setting awaitWriteFinish to true (or a truthy value) will poll file size, holding its add and change events until the size does not change for a configurable amount of time. The appropriate duration setting is heavily dependent on the OS and hardware. For accurate detection this parameter should be relatively high, making file watching much less responsive. Use with caution.
chokidar Perfomance options can be found here: https://github.com/paulmillr/chokidar#performance
Inject
You can send commands to tail-file in runtime. For example, create tail-file node, then inject necessary parameters (in json format) with inject node.
Inject Example
stop tail:
    "topic": "tail-file-stop"
start tail:
    "topic": "tail-file-start"
change filename:
    "topic": "tail-file-filename",
    "payload": "c:/new_file.log"
full config parameters (default):
    "topic": "tail-file-config",
    "payload": {
        "filename": "",
        "createFile": false,
        "mode": "",
        "encoding": "utf-8",
        "split": true,
        "separator": "[\r]{0,1}\n",
        "fromBeginning": false,
        "flushAtEOF": false,
        "rememberLast": true,
        "lineBytes": 512,
        "limitSize": true,
        "maxBytes": 5120,
        "skipBlank": true,
        "useTrim": true,
        "sendError": false,
        "interval": 100,
        "chokidar": {
            "persistent": true,
            "ignoreInitial": true,
            "usePolling": true,
            "interval": 100,
            "binaryInterval": 300,
            "alwaysStat": true,
            "awaitWriteFinish": {
                "stabilityThreshold": 200,
                "pollInterval": 100
            "ignorePermissionErrors": true,
            "atomic": true
"Rewritable file" mode:
    "payload": {
        "filename": "",
        "mode": "replaced",
        "split": false,
        "lineBytes": 512,
        "limitSize": true,
        "maxBytes": 5120,
        "skipBlank": false,
        "useTrim": false,
        "interval": 200
example of changing chokidar parameters only:
    "payload": {
        "chokidar": {
            "usePolling": true,
                "stabilityThreshold": 350
reset / revert all parameters to default:
    "payload": {}
Version: 1.2.6
Updated 8 years, 7 months ago
25 in the last week
  • tail-file
  • tail
  • tail-file
  • file
  • logs
  • windows
