node-red-contrib-symi 2.2.0
Node-RED nodes for smart home device communication with Home Assistant integration, supporting HassKit, Clowire, Alive, LF and complete Symi protocols
npm install node-red-contrib-symi
Node-RED Contrib Symi
npm version npm downloads
Node-RED nodes for smart home device communication with Home Assistant integration, supporting multiple protocols including HassKit, Clowire, Alive, LF and complete Symi protocols.
πŸ”Œ Dual Communication Support
  • TCP Network Communication: For Ethernet-connected devices
  • Serial Communication: RS485/RS232 support with full configuration options
🏠 Device Support
  • Climate Control: Temperature, humidity, HVAC systems
  • Lighting: Switches, dimmers, RGB controls
  • HVAC: Air conditioning, heating systems
  • Curtains: Motorized blinds and curtains
  • Heating: Floor heating systems
  • Ventilation: Fresh air systems
  • Scene Control: Multi-device scene management
  • Panel Control: Touch panel interfaces
πŸ“‘ Protocol Support
  • CLOWIRE: 9-byte frame protocol with CRC16 checksum
  • HASSKIT: 8-byte frame protocol for climate control
  • ALIVE: Heartbeat and keep-alive mechanism
  • LF: Lightweight protocol for simple devices
  • SYMI (δΊ–η±³): 15-byte frame protocol with comprehensive device support
Quick Start
  1. Install the package in your Node-RED environment
  2. Restart Node-RED to load the new nodes
  3. Find the nodes in the "symi" category in the palette
  4. Configure communication:
    • Drag a "symi config" node to configure TCP or Serial connection
    • Choose your communication method and set parameters
  5. Add devices: Drag device nodes and link them to your config
TCP Network Configuration
Host: 192.168.1.100
Port: 8666
Serial Communication Configuration
Serial Port: /dev/ttyUSB0 (Linux) or COM1 (Windows)
Baud Rate: 9600, 19200, 38400, 115200
Data Bits: 5, 6, 7, 8
Stop Bits: 1, 2
Parity: None, Even, Odd
Device Parameters
  • Device UID: Unique identifier for each device (e.g., 1001, 2001)
  • Device Address: Bus address for the device (1-255)
  • Device Channel: Internal channel number for multi-channel devices
Available Nodes
Configuration Node
  • symi config: Communication configuration (TCP/Serial)
Device Nodes
  • climate board: Climate control and monitoring
  • switch board: Switch and relay control
  • light board: Lighting control and dimming
  • hvac board: HVAC system control
  • curtain board: Curtain and blind control
  • heating board: Floor heating control
  • ventilation board: Fresh air system control
  • scene board: Scene management
  • panel board: Touch panel interface
Protocol Details
SYMI Protocol (δΊ–η±³)
15-byte frame structure supporting:
  • 0x01: Light devices (on/off, dimming, color)
  • 0x02: Air conditioning (temperature, mode, fan speed)
  • 0x03: Curtains (open/close, position)
  • 0x05: Floor heating (temperature control)
  • 0x06: Fresh air systems (fan control, air quality)
CLOWIRE Protocol
9-byte frame with CRC16 checksum for reliable communication.
HASSKIT Protocol
8-byte frame optimized for Home Assistant integration.
Examples
Basic Switch Control
// Configure TCP connection
  "connectionType": "tcp",
  "host": "192.168.1.100",
  "port": 8666
// Switch device
  "deviceUID": 1001,
  "deviceAddress": 1,
  "deviceChannel": 0,
  "protocol": "CLOWIRE"
Serial RS485 Setup
// Configure Serial connection
  "connectionType": "serial",
  "serialPort": "/dev/ttyUSB0",
  "baudRate": 9600,
  "dataBits": 8,
  "stopBits": 1,
  "parity": "none"
Requirements
  • Node.js: >= 14.0.0
  • Node-RED: >= 3.0.0
Dependencies
  • serialport: Serial communication support
  • @serialport/parser-readline: Serial data parsing
  • ws: WebSocket communication
  • async-lock: Asynchronous operation locking
Changelog
v2.2.0
  • βœ… Added serial communication support (RS485/RS232)
  • βœ… Dual communication mode (TCP + Serial)
  • βœ… Complete serial configuration options
  • βœ… Dynamic connection type switching
  • βœ… Preserved all original protocol functionality
  • βœ… Enhanced device configuration documentation
v2.1.0
  • Initial release with TCP communication
  • Support for 5 protocols and 10 device types
  • Home Assistant integration
MIT
Support
Version: 2.2.0
Updated 1 year, 6 months ago
27 in the last week
  • symi config
  • climate board
  • switch board
  • light board
  • hvac board
  • curtain board
  • heating board
  • ventilation board
  • scene board
  • panel board
  • home-assistant
  • hasskit
  • clowire
  • alive
  • lf
  • symi
  • panel
  • industrial
  • tcp
  • serial
  • rs485
  • rs232
  • climate
  • switch
  • automation
  • smart-home
  • iot
  • modbus
  • protocol
