node-red-contrib-swagger-petstore 2.0.7
Node-RED node for swagger-petstore
npm install node-red-contrib-swagger-petstore
This is a sample server Petstore server. You can find out more about Swagger at http://swagger.io or on irc.freenode.net, #swagger. For this sample, you can use the api key special-key to test the authorization filters.
To install the stable version use the Menu - Manage palette - Install option and search for node-red-contrib-swagger-petstore, or run the following command in your Node-RED user directory, typically ~/.node-red
Methods
POST /pet/{petId}/uploadImage
uploads an image
petId : integer
additionalMetadata : string
file : file
Accept : 'application/json'
Content-Type : 'multipart/form-data'
POST /pet
Add a new pet to the store
body :
Content-Type : 'application/json'
PUT /pet
Update an existing pet
body :
GET /pet/findByStatus
Multiple status values can be provided with comma separated strings
status : array
GET /pet/findByTags
Multiple tags can be provided with comma separated strings. Use tag1, tag2, tag3 for testing.
tags : array
GET /pet/{petId}
Returns a single pet
petId : integer
POST /pet/{petId}
Updates a pet in the store with form data
petId : integer
status : string
DELETE /pet/{petId}
Deletes a pet
api_key : string
petId : integer
POST /store/order
Place an order for a pet
body :
GET /store/order/{orderId}
For valid response try integer IDs with value >= 1 and <= 10. Other values will generated exceptions
orderId : integer
DELETE /store/order/{orderId}
For valid response try integer IDs with positive integer value. Negative or non-integer values will generate API errors
orderId : integer
GET /store/inventory
Returns a map of status codes to quantities
POST /user/createWithArray
Creates list of users with given input array
body :
POST /user/createWithList
body :
GET /user/{username}
Get user by user name
username : string
PUT /user/{username}
This can only be done by the logged in user.
username : string
body :
DELETE /user/{username}
username : string
GET /user/login
Logs user into the system
username : string
password : string
GET /user/logout
Logs out current logged in user session
POST /user
body :
Apache 2.0
http://www.apache.org/licenses/LICENSE-2.0.html
Version: 2.0.7
Updated 4 years, 6 months ago
License: Apache 2.0
3 in the last week
  • swagger-petstore
  • swagger-petstore-service
  • swagger-petstore
  • rest
