node-red-contrib-surepetcare 0.6.2
Node-RED nodes for SurePetcare/SureFlap Connect smart cat flaps
npm install node-red-contrib-surepetcare
Node-RED nodes for the SurePetcare cloud API. Monitor pet locations, control SureFlap cat flap lock states, and query pet activity stats from your Node-RED flows.
Disclaimer: This project is not affiliated with, endorsed by, or in any way associated with Sure Petcare Ltd. It is an independent, community-developed integration created by happy users of their hardware and software. SurePetcare, SureFlap, and SureFeed are trademarks of Sure Petcare Ltd. Use of this package is at your own risk. The underlying API is unofficial and reverse-engineered by the community - it may change or break without notice.
surepetcare-config
Config node. Holds your SurePetcare account credentials and manages the API token lifecycle.
surepetcare-pets
Polls the SurePetcare API for pet locations. Emits one message per pet:
Property Type Description
payload.id number Pet ID
payload.name string Pet name
payload.location string inside or outside
payload.since string ISO 8601 timestamp of last position change
Send any message to the input to trigger an immediate poll. Set Poll interval to 0 to disable automatic polling.
surepetcare-control
Sets the lock state of a SureFlap cat flap, or renames the device.
msg.payload.lockState Meaning
0 Unlocked (both directions)
1 Locked in (entry only)
2 Locked out (exit only)
3 Locked (both directions)
Both deviceId and lockState can be overridden per message via msg.payload. If msg.payload.name is set instead, the device is renamed rather than locked.
surepetcare-pet-control
Sets a pet's inside/outside status directly - useful for linking an automation (e.g. a door sensor) to a pet's recorded location, without needing a flap event.
Both petId and location (inside/outside) can be overridden per message via msg.payload.
surepetcare-devices
Polls the SurePetcare API for device status. Emits one message per device:
payload.deviceId string Device ID, for use with surepetcare-control
payload.name string Device name
payload.lockingMode number Live lock state - see below
payload.curfew array Configured curfew windows: [{ lock_time, unlock_time, enabled }]
lockingMode reports more than the settable lock states, since it reflects what the flap is actually doing right now:
lockingMode Meaning
0-3 Same as surepetcare-control's lockState above
4 Locking deferred to the device's own curfew schedule
-1 Curfew currently engaged (exit blocked, entry still allowed)
-2 Curfew currently released
-3 Curfew status unknown
surepetcare-report
On-demand lookup of aggregated inside/outside activity stats for a pet - the same data behind the app's activity view.
payload.petId string Pet ID that was queried (overridable via msg.payload.petId)
payload.fromDate string Start date used, if a range was given (YYYY-MM-DD)
payload.toDate string End date used, if a range was given (YYYY-MM-DD)
payload.report object Raw { movement, feeding, drinking } data. Movement entries have from/to timestamps and a duration in seconds spent outside.
msg.payload.fromDate/msg.payload.toDate must be given together, or omitted together. Omitting both uses the API's default range - the underlying endpoint can return a very large response when unbounded, so prefer an explicit range for anything beyond a quick check. This is a one-off lookup triggered by an input message, not a poller.
Reliability
Every API call - polling or control - automatically retries on 429 (rate limit) and network errors with exponential backoff before giving up, so a single dropped request (e.g. a curfew unlock command) doesn't leave the flap stuck in the wrong state until the next scheduled event.
Examples
The examples/ directory has ready-to-import flows (Node-RED menu -> Import -> select file):
  • curfew-full-lock.json - upgrades the flap's own curfew from a one-way lock (exit blocked, entry still allowed) to a full both-ways lock, but only once every pet's chip is confirmed inside, so a straggler is never locked out.
  • night-lockout.json - forces the flap locked on a fixed schedule as a backup for when the app's own curfew doesn't engage reliably.
  • daily-flap-rename.json - example of using the rename capability.
  • cat-ev-tracker.json - example pet-location tracking flow.
  1. Add any surepetcare-pets, surepetcare-control, surepetcare-pet-control, surepetcare-devices, or surepetcare-report node to your flow
  2. Create a new SurePetcare config node with your account email and password
  3. A stable device ID is generated automatically on first save
References
Version: 0.6.2
Updated 1 month, 3 weeks ago
462 in the last week
  • surepetcare-config
  • surepetcare-pets
  • surepetcare-control
  • surepetcare-pet-control
  • surepetcare-devices
  • surepetcare-report
  • sureflap
  • surepetcare
  • cat-flap
  • pet
