node-red-contrib-super-config 1.0.0
Centralized configuration node for Node-RED with Monaco editor autocomplete, type hints, and real-time value preview
npm install node-red-contrib-super-config
A centralized configuration node for Node-RED with Monaco editor autocomplete, type hints, and real-time value preview.
Define your configuration once — get IntelliSense everywhere.
Node-RED npm license
  • Autocomplete in Function nodes — type cfg. and see all config keys with descriptions and live values
  • Nested objects — config supports arbitrary depth (cfg.email.smtp.host)
  • Environment variables — use ${ENV_VAR} in any string value, resolved automatically at deploy time
  • Visual tree editor — add/remove/nest keys directly in the node UI
  • JSON editor — switch to raw JSON editing with one click
  • Type safety — generates TypeScript interfaces injected into Monaco editor
Via Node-RED Palette Manager
  1. Open Node-RED
  2. Go to Menu → Manage Palette → Install
  3. Search for node-red-contrib-super-config
  4. Click Install
Via npm
Restart Node-RED after installation.
Quick Start
1. Add the node
Drag super config from the palette onto your flow. You'll find it in the Super Config category.
2. Define your configuration
Double-click the node to open the editor:
Key Type Value Description
email object Email service config
→ host string ${SMTP_HOST} SMTP server host
→ sender string [email protected] Default sender
apiToken string ${API_TOKEN} External API token
debugMode boolean false Enable debug logging
allowedRoles array ["admin","editor"] Permitted roles
3. Deploy
Click Deploy. The config is written to context and types are generated.
4. Use in Function nodes
/** @type {SuperConfig} */
const cfg = global.get("config");
const smtpHost = cfg.email.host;      // autocomplete works here
const sender = cfg.email.sender;       // hover shows description + value
const token = cfg.apiToken;
After deploy, refresh the browser (F5) to load updated type definitions. Then autocomplete will show all your config keys with descriptions and real values on hover.
Value Types
Type Description Example value
string Text value. Supports ${ENV_VAR} syntax https://${API_HOST}/v1
number Numeric value 8080
boolean true or false true
array JSON array ["admin","user"]
object Nested object with child keys (use tree editor)
Environment Variables
Any string value containing ${VAR_NAME} will be automatically resolved from environment variables at deploy time.
Value: https://${API_HOST}/api/v1
Result: https://production.example.com/api/v1
If the variable is not set, the ${VAR_NAME} placeholder remains as-is.
Scope
Scope Access in Function nodes
Global global.get("config")
Flow flow.get("config")
JSON Editor
Click the JSON button in the node editor to switch to raw JSON editing mode. Format:
  "email": {
    "_type": "object",
    "_desc": "Email service config",
    "_children": {
      "host": {
        "_type": "string",
        "_desc": "SMTP server host",
        "_value": "${SMTP_HOST}"
  "debugMode": {
    "_type": "boolean",
    "_desc": "Enable debug logging",
    "_value": "false"
How Autocomplete Works
The node generates TypeScript interface definitions from your config structure and injects them into the Monaco editor using two mechanisms:
  1. addExtraLib injection — types are injected into Monaco when the editor opens
  2. func.d.ts append — types are written to Node-RED's built-in type definition file
After deploy + browser refresh, writing /** @type {SuperConfig} */ before global.get("config") enables full autocomplete with descriptions and live values.
Requirements
  • Node-RED >= 2.0.0
  • Monaco editor (default in Node-RED since v2.0)
MIT
Version: 1.0.0
Updated 9 months ago
  • super-config
  • config
  • configuration
  • autocomplete
  • intellisense
  • monaco
  • global-config
  • typescript
  • jsdoc
