node-red-contrib-suncron 1.6.9
A Node-RED node that triggers configurable outgoing messages based on the position of the sun
npm install node-red-contrib-suncron
SunCron
A Node-RED node that can output configurable messages at significant sun events
Supported Sun Events
  • Sunrise
  • Sunrise End
  • Golden Hour End
  • Solar Noon
  • Golden Hour
  • Sunset Start
  • Sunset
  • Dusk
  • Nautical Dusk
  • Night
  • Nadir
  • Night End
  • Nautical Dawn
  • Dawn
For each of the above sun events a distinct msg.payload and msg.topic can be configured. It is also possible to specify an offset to adjust the event time.
The location (lat / lon) can either be entered manually or retrieved automatically from your browser via the location button.
example
The offsets can be overwritten at runtime by passing a config object as msg.payload to the suncron node. All attributes are optional. Offsets need to be expressed in seconds as positive or negative integer values. Below example adjusts the offset for the dusk event to -2 minutes (-120 seconds) and all others to 0 seconds.
    "sunrise": 0,
    "sunriseEnd": 0,
    "goldenHourEnd": 0,
    "solarNoon": 0,
    "goldenHour": 0,
    "sunsetStart": 0,
    "sunset": 0,
    "dusk": -120,
    "nauticalDusk": 0,
    "night": 0,
    "nadir": 0,
    "nightEnd": 0,
    "nauticalDawn": 0,
    "dawn": 0
Outgoing messages
Sun events
The node will emit messages at the specified sun events (respecting offsets) or when it receives an inbound msg with a non-object payload, e.g. true. Outbound messages will have a msg.payload and msg.topic as configured in the editor. Those messages also have a schedule attribute containing an object with details about the schedule of the current date. The schedule contains only events which have been configured with a payload.
Each event has the following attributes:
Attribute Description
event The name of the sun event
sunEventTime The unadjusted time of the respective sun event
cronTime The adjusted time, taking the offset into account
offset The configured offset in seconds
Example msg.schedule object
  "sunrise": {
      "event": "sunrise",
      "sunEventTime": "2022-02-26T06:29:51",
      "cronTime": "2021-02-26T06:29:51",
      "offset": 0
  "sunriseEnd": {
      "event": "sunriseEnd",
      "sunEventTime": "2022-02-26T06:33:24",
      "cronTime": "2022-02-26T07:33:24",
      "offset": 3600
  "dawn": {
      "event": "dawn",
      "sunEventTime": "20221-02-26T05:54:49",
      "cronTime": "2022-02-26T05:44:49",
      "offset": -600
Schedule events
If the checkbox "Emit schedule when updated" is ticked, the node will emit additional messages whenever the schedule gets updated. This happens on startup, when offsets are overridden at runtime, and shortly after midnight. Those messages will contain the schedule object as msg.payload (same structure as above) and the string "suncron:schedule" as msg.topic.
Known issues
Depending on your configured location (lat / lon) and time of the year, you might notice some sun events not being triggered. This is not an error but how lighting works on earth. For example in polar regions, they sometimes have day (or night) for weeks at a time. But even in Berlin / Germany there might not always be a distinct 'night' event as the sun during summer does not go below the astronomical twilight threshold.
Contributions and Suggestions
... are always welcome! Just file a GitHub issue or pull request!
Version: 1.6.9
Updated 1 year, 1 month ago
Rating: 5.0 5
311 in the last week
  • suncron
  • smart home
  • sun
  • sunset
  • sunrise
  • dusk
  • noon
  • cron
  • timer
  • timer clock
