node-red-contrib-suncalcinput 1.0.0
A Node-RED node to provide a signal at sunrise and sunset. Supports sepcifying position via input.
npm install node-red-contrib-suncalcinput
A Node-RED node to provide a signal at sunrise and sunset. Where location can be changed with the input.
Uses the suncalc npm to generate an output at sunrise and sunset based on a specified location.
Several choices of definition of sunrise and sunset are available, see the suncalc module for details.
The node provide two outputs. The first output emits a msg.payload of 1 or 0 every minute depending if day-time (1) or night-time (0).
The second output emits only on the transition between night to day (-> 1) or day to night (-> 0).
It also sets the msg.topic to sun and msg.moon to the fraction of the moon currently visible (a value between 0 for no moon and 1 for full moon).
The node provide one input. Setting msg.lat to latitude and msg.lon to longitude will change the position.
Acknowledgement
This node is based on node-red-node-suncalc which offers the same functionality except for the posibility to change position dynamically.
Version: 1.0.0
Updated 7 years, 11 months ago
10 in the last week
  • sunriseinput
  • suncalc
  • suncalcinput
