node-red-contrib-subflow2node 0.1.0
Node-RED node for converting subflow to node
npm install node-red-contrib-subflow2node
Node-RED node for packageng exported subflow JSON definition to node module
subflow2node node is a node for creating a subflow module that can be installed from manage palette menu of Node-RED editor as described documentation page([Packaging a Subflow as a module : Node-RED]).
Since package generation with tools and/or Node-RED editor are being considered by core Node-RED project, this node is intended as a substitution until then.
The subflow2node node accepts the exported SUBFLOW JSON format data and outputs the npm package. A subflow module can be added to the palette by saving this package to a file and uploading it from the manage palette menu in the Node-RED editor.
This node also provides experimental support of flow encoding feature discussed here. Decoding key for flow should be defined by OS environment variable NR_FLOW_DECODE_KEY.
Note: A npm module created by this node uses APIs that require at least Node-RED 1.3.
Note: This node expects subflow definition exported from subflow template. Also, generated NPM package may not work for sufblow definitions with nested subflow.
Example
Import example from Inport/Examples/node-red-contrib-subflow2node.
  • 01 - generate package
    This example use a template node to define subflow json data and a file node to write package.
  • 02 - simple Web UI
    This example flow creates a HTTP end-point at http://localhost:1880/subflow2node that provides a simple UI for subflow module generation. In this US, write subflow JSON data, readme in Markdown, and licence text. Pressing send button moves to package download page.
    Simple Web UI
    Example Sublow Definition:
  [{"id":"921a4b1d.07bb68","type":"subflow","name":"QRcode","info":"","category":"","in":[{"x":140,"y":120,"wires":[{"id":"e563f491.e443f8"}]}],"out":[{"x":380,"y":120,"wires":[{"id":"e563f491.e443f8","port":0}]}],"env":[],"meta":{"module":"node-red-contrib-qrcode","type":"qrcode","version":"0.1.0","author":"[email protected]","desc":"Node-RED node for converting string to QRcode","keywords":"Node-RED, subflow, QRcode","license":"Apache-2.0"},"color":"#87A980","icon":"font-awesome/fa-qrcode"},{"id":"e563f491.e443f8","type":"function","z":"921a4b1d.07bb68","name":"","func":"qrcode.toString(msg.payload, (err,str) => {\n    if (err) {\n        node.error(err);\n        return;\n    }\n    node.send({payload: str});\n});","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[{"var":"qrcode","module":"qrcode"}],"x":260,"y":120,"wires":[[]]}]
Version: 0.1.0
Updated 6 years ago
7 in the last week
  • sf to node
  • subflow
