node-red-contrib-string-filter 0.0.1
A node that filters strings based on the configuration.
npm install node-red-contrib-string-filter
Node-RED Contrib String Filter
The node-red-contrib-string-filter node is a Node-RED module that enables filtering of messages based on a user-defined string. This node allows users to define a specific string pattern, and only messages containing this pattern will be allowed to pass through the node.
  1. Make sure you have Node-RED installed. You can install it via npm if you haven't already:
    npm install -g node-red
  2. Install the node-red-contrib-string-filter node either through the Node-RED palette manager or via npm:
  3. Restart your Node-RED instance to ensure the new node is loaded.
  1. Drag and drop the "String Filter" node from the Node-RED palette onto your flow canvas.
  2. Configure the node by entering the string you want to filter for in the node settings.
  3. Connect the node to your input source (e.g., an MQTT node, an inject node, etc.).
  4. Deploy your flow.
Node Configuration
  • String to Filter: Enter the string that you want the node to filter for. Messages containing this string will be allowed to pass through.
  • Enable/Disable: You can enable or disable the node dynamically by sending a boolean message with true to enable and false to disable.
Author
This Node-RED node was created by Harshad Joshi.
This project is licensed under the GPL-3.0 License.
GitHub Repository
You can find the source code and report issues on GitHub.
Applications
  • Filtering messages based on specific keywords or phrases.
  • Controlling the flow of messages based on the presence or absence of certain strings.
  • Implementing conditional logic in your Node-RED flows.
Version: 0.0.1
Updated 2 years, 10 months ago
License: GPL-3.0
Rating: 5.0 5
3 in the last week
  • string-filter
  • peak
  • value
  • range
  • filter
  • string filter
