node-red-contrib-streamdeck-ws 1.1.0
Companion node to work with Stream Deck WS plugin
npm install node-red-contrib-streamdeck-ws
About
node-red-contrib-streamdeck-ws is a Node-RED module intended to be used in conjuction with Stream Deck WS module for Stream Deck
Purpose
Stream Deck WS acts like a proxy and forwards key events from the Stream Deck to a Web Socket service of your choice. A very popular way to run a quick and flexible Web Socket server is by using Node-RED and its standard websocket in/out node.
You can set it all up in Node-RED without using node-red-contrib-streamdeck-ws, but it makes things a little bit harder.
With node-red-contrib-streamdeck-ws, you place a sd input node after your websocket in and format the response event in a sd output node before websocket out, and you can configure the returned key state in the node properties.
ScreenShot 1
ScreenShot 2
Version: 1.1.0
Updated 4 years, 1 month ago
15 in the last week
  • sd-input
  • sd-output
  • streamdeck
