node-red-contrib-streamdeck 1.0.2
A Node-RED node to interact with the Elgato Stream Deck products
npm install node-red-contrib-streamdeck
A Node-RED node to interact with the Elgato Stream Deck products.
Local
npm install --save node-red-contrib-streamdeck
Global
npm install -g node-red-contrib-streamdeck
Linux
On Linux, you will need to add these to /etc/udev/rules.d/50-elgato.rules :
SUBSYSTEM=="input", GROUP="input", MODE="0666"
SUBSYSTEM=="usb", ATTRS{idVendor}=="0fd9", ATTRS{idProduct}=="0060", MODE:="666", GROUP="plugdev"
SUBSYSTEM=="usb", ATTRS{idVendor}=="0fd9", ATTRS{idProduct}=="0063", MODE:="666", GROUP="plugdev"
SUBSYSTEM=="usb", ATTRS{idVendor}=="0fd9", ATTRS{idProduct}=="006c", MODE:="666", GROUP="plugdev"
SUBSYSTEM=="usb", ATTRS{idVendor}=="0fd9", ATTRS{idProduct}=="006d", MODE:="666", GROUP="plugdev"
And run sudo udevadm control --reload-rules
stream deck in
The input node will allow you to get which keys are pressed on the unit.
The key index will be sent as msg.topic as an integer starting from 0. The key state (down or up) will be sent as an integer in msg.payload. 1 is down and 0 is up.
stream deck out
The output node is used to send images to the keys and control various functions.
Inputs
payload: This should be an object containing a command property. Some commands require additional properties, described in the commands section below.
topic: An integer representing the index of the key to send the command to, starts at 0.
Commands
fillColor array
Should have a value property containing an array of color values in RGB order, between 0 and 255. keyIndex should be passed as the topic.
fillImage path | url | buffer
Should have an image property containing either a file path, url or buffer containing image data. keyIndex should be passed as the topic.
fillPanel path | url | buffer
Same as fillImage but will fill the entire panel.
clearKey
Will clear a key with keyIndex passed as topic.
clearAllKeys
Will clear the whole panel.
resetToLogo
Will show the default Stream Deck logo.
setBrightness integer
Should have a value property containing an integer between 0 and 100.
listStreamDecks
Will list the available Stream Decks.
Example
  "topic": 3
  "payload" : {
    "command": "fillImage",
    "image": "./node-red.png"
Version: 1.0.2
Updated 6 years, 3 months ago
10 in the last week
  • streamdeck-in
  • streamdeck-out
  • elgato
  • streamdeck
