node-red-contrib-stream-client 0.1.3
A Node-RED node to stream NDJSON over HTTP with auto-reconnect and configurable headers.
npm install node-red-contrib-stream-client
A Node-RED input node that connects to an HTTP NDJSON stream and parses each line into a separate message.
  • Auto-reconnect with configurable delay
  • Supports Bearer token and custom headers
  • Accepts any query parameters
  • Line-by-line JSON parsing (NDJSON)
  • Debug option for verbose logging
In your Node-RED user directory:
Add the Stream Client node to your flow. Configure:
  • URL: Base endpoint URL
  • Bearer Token: (optional) Authorization token
  • Extra Headers: JSON string for additional headers
  • Query Params: e.g. foo=1&bar=2
  • Reconnect Delay: ms to wait before retrying
  • Debug: Logs more info to Node-RED console
Output
Each message has:
  "payload": { ...parsed line from stream... }
Example
curl -H "Authorization: Bearer token" \
  'https://example.com/api/stream?type=event&id=123'
This would stream lines like:
{"event":"start","id":123}
{"event":"stop","id":123}
And emit one Node-RED message per line.
MIT
Version: 0.1.3
Updated 1 year, 3 months ago
65 in the last week
  • stream-client
  • stream
  • ndjson
  • http
  • flowfuse
