node-red-contrib-storfly-ies-vtview 0.0.1
StorFly IES vtView node
npm install node-red-contrib-storfly-ies-vtview
node-red-contrib-storfly-ics-vtview
A Node-RED node to display, transfer vtView data
Run the following command in your Node-RED user directory – typically ~/.node-red:
npm i node-red-contrib-storfly-ics-vtview
Provides one palette node which will transfer, display vtView information from storfly device to IoT Gateway.
Input
Parametters Data Type Notes
IP Address string IP address of StorFly ICS
Username string admin
Password string Serial number of the device
Output
Parametters Data Type Unit Default Value Notes
revision int Revision of this structure
remainingTBW int TB TB = Terra byte, 1TB = 1024 GB
dataWritten double GB GB = Giga byte
estimateEOL double day 3650 Estimate Time remaining in days
remainingLife int percentage Start from 100% decreasing to 0%
yearInService double day Start from the day the StorFly ICS is commissioned for service.
timestamp int Timestamp (date & time) of the most recent vtView record
serial string
ipAddress string
errorMessage string "Not enough vtview data" or "" If the usage is not a full drive-write, there is not enough usage data for vtView software to do the calculation, vtView will return "Not enough vtView data". Otherwise, this field is return empty.
Flow Example
Display vtView information to a dashboard for Light theme
https://flows.nodered.org/flow/7fcfa65f86a0e54ece2479b58286209f
Display vtView information to a dashboard for Dark theme
https://flows.nodered.org/flow/4a9192b0a0e133266c17358e42a40d05
Note: Before you use this flow, please install node-red-dashboard first
Virtium License - See file LICENSE in the source
Version: 0.0.1
Updated 8 years, 4 months ago
License: Virtium License
1 in the last week
  • Storfly ICS vtView
  • component display
  • component display mode
  • component display group
  • component display region
  • vtView
  • Virtium IoT
