node-red-contrib-stein 0.0.10
The Node node-red-contrib-stein creates task items using Stein API. This is simple node for Stein API.
npm install node-red-contrib-stein
Move your Node-RED user directory ~/.node-red
npm i node-red-contrib-stein
or
  • Go to "Palette Manager" menu on your Node-RED.
  • Search "node-red-contrib-stein" on Node-RED Library.
  • Click "Install".
Prepare your Google Sheet
Create the simple sheet contained ID, Name and Age.
Prepare your Stein API URL
Create New API from Sheet using this Google Sheet. Copy created API URL.
Sample flow for getting datas:
[{"id":"f9ce75c6.7314b8","type":"stein-get","z":"dd89b5b.4441e48","name":"","sheet":"Sheet1","apiurl":"","x":460,"y":120,"wires":[["e2e89214.1c0c5"]]},{"id":"12d9e829.970328","type":"inject","z":"dd89b5b.4441e48","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":260,"y":120,"wires":[["f9ce75c6.7314b8"]]},{"id":"e2e89214.1c0c5","type":"debug","z":"dd89b5b.4441e48","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":650,"y":120,"wires":[]},{"id":"cd36427a.414a8","type":"comment","z":"dd89b5b.4441e48","name":"Get","info":"","x":210,"y":80,"wires":[]}]
Import this flow. This is for getting datas. This flow will get sheet name Sheet1.
Setting Stein API URL
Setting Stein API URL.
Add new stein-config.
stein-config setting.
  • API Name
    • Set freely.
  • API URL
    • Set copied current Stein API URL.
Click inject node
The Stein get node return status text in the bottom of node when you clicked the inject node.
The node will return Sheet rows data this to the debug node.
Example
In these example, continue to use the usage sheet data.
Search
It searches ID:1 and gets the row data.
Like this.
Sample flow for search rows.
[{"id":"2f4fa1e3.fb4dce","type":"inject","z":"dd89b5b.4441e48","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":260,"y":380,"wires":[["2e1b2bab.3bf494"]]},{"id":"d461f009.a268a","type":"debug","z":"dd89b5b.4441e48","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":930,"y":380,"wires":[]},{"id":"2e1b2bab.3bf494","type":"change","z":"dd89b5b.4441e48","name":"search ID:1","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"ID\":\"1\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":430,"y":380,"wires":[["e431043c.b31448"]]},{"id":"e431043c.b31448","type":"stein-search","z":"dd89b5b.4441e48","name":"","sheet":"Sheet1","apiurl":"dd66eff1.2481c","x":710,"y":380,"wires":[["d461f009.a268a"]]},{"id":"2bb0e1c4.09a60e","type":"comment","z":"dd89b5b.4441e48","name":"Search","info":"","x":210,"y":340,"wires":[]},{"id":"dd66eff1.2481c","type":"stein-config","z":"","name":"Sample API"}]
The detail of this node usage see the node information.
Add Rows
It adds rows.
  • add 2 rows (array) change node.
    • This sample add multiple row data as array.
  • add 1 row (object) change node.
    • This sample add 1 row data as object.
add 1 row (object) sample worked like this. It added 1 row data as object.
Sample flow for add rows.
[{"id":"b2ee304c.706ab","type":"stein-addrows","z":"dd89b5b.4441e48","name":"","sheet":"Sheet1","apiurl":"dd66eff1.2481c","x":740,"y":380,"wires":[["b06abc1f.d6f0d"]]},{"id":"32f62e3e.f720c2","type":"inject","z":"dd89b5b.4441e48","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":280,"y":380,"wires":[["8d5f601b.011d7"]]},{"id":"8d5f601b.011d7","type":"change","z":"dd89b5b.4441e48","name":"add 2 rows (array)","rules":[{"t":"set","p":"payload","pt":"msg","to":"[{\"ID\":\"5\",\"Name\":\"E\",\"Age\":\"55\"},{\"ID\":\"6\",\"Name\":\"F\",\"Age\":\"66\"}]","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":380,"wires":[["b2ee304c.706ab"]]},{"id":"b06abc1f.d6f0d","type":"debug","z":"dd89b5b.4441e48","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":950,"y":380,"wires":[]},{"id":"91a2a69.56b7858","type":"comment","z":"dd89b5b.4441e48","name":"Add Rows","info":"","x":240,"y":340,"wires":[]},{"id":"4dccf9ea.2a9948","type":"stein-addrows","z":"dd89b5b.4441e48","name":"","sheet":"Sheet1","apiurl":"dd66eff1.2481c","x":740,"y":440,"wires":[["3a9493da.90ecbc"]]},{"id":"fccecb70.33a648","type":"inject","z":"dd89b5b.4441e48","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":280,"y":440,"wires":[["2abff338.50722c"]]},{"id":"2abff338.50722c","type":"change","z":"dd89b5b.4441e48","name":"add 1 row (object)","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"ID\":\"5\",\"Name\":\"E\",\"Age\":\"55\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":440,"wires":[["4dccf9ea.2a9948"]]},{"id":"3a9493da.90ecbc","type":"debug","z":"dd89b5b.4441e48","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":950,"y":440,"wires":[]},{"id":"dd66eff1.2481c","type":"stein-config","z":"","name":"Sample API"}]
Update Row
It searches ID:5 and updates the row data Age:12.
After Add Rows sample, like this. The sample updated 2 ID:5 rows to Age:12.
Sample flow for update row.
[{"id":"149255d9.32cd7a","type":"stein-updaterows","z":"dd89b5b.4441e48","name":"","sheet":"Sheet1","apiurl":"dd66eff1.2481c","x":730,"y":640,"wires":[["7e903643.2df8d8"]]},{"id":"7e903643.2df8d8","type":"debug","z":"dd89b5b.4441e48","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":930,"y":640,"wires":[]},{"id":"73469a33.1652c4","type":"inject","z":"dd89b5b.4441e48","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":260,"y":640,"wires":[["6c49017.1db09"]]},{"id":"6c49017.1db09","type":"change","z":"dd89b5b.4441e48","name":"update search ID:5 set Age:12","rules":[{"t":"set","p":"payload","pt":"msg","to":"{}","tot":"json"},{"t":"set","p":"payload.search","pt":"msg","to":"{\"ID\":\"5\"}","tot":"json"},{"t":"set","p":"payload.set","pt":"msg","to":"{\"Age\":\"12\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":490,"y":640,"wires":[["149255d9.32cd7a"]]},{"id":"5807a984.3cd0c8","type":"comment","z":"dd89b5b.4441e48","name":"Update Rows","info":"","x":230,"y":600,"wires":[]},{"id":"dd66eff1.2481c","type":"stein-config","z":"","name":"Sample API"}]
Delete
It searches ID:5 and deletes the row data. In default, its delete limit is 1.
Like this. It deleted only one ID:5 row.
Sample flow for delete row.
[{"id":"5e9537b7.050458","type":"stein-deleterows","z":"dd89b5b.4441e48","name":"","sheet":"Sheet1","apiurl":"dd66eff1.2481c","x":720,"y":720,"wires":[["e325bfe9.1b344"]]},{"id":"22b88617.0c51ca","type":"inject","z":"dd89b5b.4441e48","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":260,"y":720,"wires":[["f6ca3915.d8a318"]]},{"id":"f6ca3915.d8a318","type":"change","z":"dd89b5b.4441e48","name":"delete ID:5","rules":[{"t":"set","p":"payload","pt":"msg","to":"{}","tot":"json"},{"t":"set","p":"payload","pt":"msg","to":"{\"ID\":\"5\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":430,"y":720,"wires":[["5e9537b7.050458"]]},{"id":"e325bfe9.1b344","type":"debug","z":"dd89b5b.4441e48","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":930,"y":720,"wires":[]},{"id":"bb99b592.4ad848","type":"comment","z":"dd89b5b.4441e48","name":"Delete Rows","info":"","x":230,"y":680,"wires":[]},{"id":"dd66eff1.2481c","type":"stein-config","z":"","name":"Sample API"}]
History
  • v0.0.10
    • Added examples at README.md.
  • v0.0.9
    • Added each error handling.
    • In using stein-js-client changed Promise "then" to wrapped await/async.
  • v0.0.7 - 0.0.8
    • Improved node status to display the detail.
    • Improved node status when connecting color.
    • Changed delete API main param from payload.search to payload.
      • If needed param is one value, It's assign one value directly to the payload as possible as it can for now.
  • v0.0.5 - v0.0.6
    • Fixed stein-js-client version.
    • The node mistook stein-js-client version between v0.0.3 to v0.0.5.
  • v0.0.4
    • Added delete API node.
    • Fixed sheet name behavior.
    • Fixed update API node from condition param to search.
  • v0.0.3
    • First release.
MIT License
Version: 0.0.10
Updated 6 years, 3 months ago
11 in the last week
  • stein-config
  • stein-get
  • stein-search
  • stein-addrows
  • stein-updaterows
  • stein-deleterows
  • stein
