node-red-contrib-start 1.0.0
A simple node that executes the flow
npm install node-red-contrib-start
A node that allows to start any flow with a payload as "Hello World".
Pre-requisites
The Node-RED Start node requires Node-RED to be installed.
To install the stable version use the Menu - Manage palette option and search for node-red-contrib-start, or run the following command in your Node-RED user directory - typically ~/.node-red:
Or else install the package directly from Manage Palette
Restart your Node-RED instance and you should have a "start" node available in the palette.
Get Started
1. After installation, drag the start node from the palette to the workspace.
2. Double click on the node to add msg.payload.
3. Test the flow by clicking on "Test Without Deploy".
test without deploy
The start node can be utilized in any flow as a starter node with any payload including strings, JavaScript objects or the current time.
Discussions and suggestions
Use the Krysp Forum: https://www.krysp.io/forum to ask questions or to discuss new features.
Version: 1.0.0
Updated 5 years, 4 months ago
Rating: 1.0 1
2 in the last week
  • start
  • start
