node-red-contrib-starlink-mini-metrics 0.1.2
Extract and normalize advanced Starlink Mini metrics from raw_status payloads in Node-RED
npm install node-red-contrib-starlink-mini-metrics
A Node-RED node that extracts and normalizes advanced metrics from a Starlink Mini raw_status payload.
This node is designed to consume messages published to MQTT (commonly starlink/mini/raw_status) and output a flattened metrics object suitable for dashboards, alerts, and storage (InfluxDB, files, etc.).
From Node-RED Palette Manager, or:
Restart Node-RED.
Typical flow:
mqtt in (starlink/mini/raw_status) → starlink mini metrics → debug/dashboard/storage
The node accepts:
  • msg.payload as an object, or
  • msg.payload as a JSON string
If Strict is enabled (default), messages missing payload.status are dropped.
Output
By default, output is written to msg.payload:
  • downlink_mbps, uplink_mbps
  • pop_ping_latency_ms
  • GPS, obstruction, alignment/boresight fields
  • ready state flags
  • (optional) ts, dish_id, serial
  • Output property: where to write the metrics object (default: payload)
  • Strict: drop message if missing status (default: true)
  • Identity fields: include ts, dish_id, serial if present (default: true)
Example flow
See examples/flow.json for an importable demo.
Companion Bridge (MQTT Publisher)
This node expects the Starlink Mini status schema commonly published by a bridge that polls the Starlink dish and publishes raw_status to MQTT.
Companion Python bridge (Docker/systemd friendly):
MIT
Support This Project
If you find this useful, star ⭐ the repo! It helps others discover it.
More Info
Blog: https://hamradiohacks.blogspot.com
GitHub: https://github.com/n3bkv
Version: 0.1.2
Updated 10 months, 1 week ago
  • starlink-mini-metrics
  • node-red-contrib
  • starlink
  • mini
  • mqtt
  • metrics
