node-red-contrib-stackhero-influxdb-v2-param 1.0.4
A Node-RED node to connect to an InfluxDB v2 database based on stackhero module.
npm install node-red-contrib-stackhero-influxdb-v2-param
Node-RED node to read and write to an InfluxDB v2 database.
Remember: if you like it, please star it! 🥰
Official repository: https://github.com/stackhero-io/node-red-contrib-stackhero-influxdb-v2
Sponsors
node-red-contrib-stackhero-influxdb-v2 is developed by Stackhero. If you are looking for powerful managed services, like InfluxDB, you should seriously consider Stackhero 🤓
We have 2 nodes here. A write node, to send data to InfluxDB and a query node, to retrieve data using the Flux language.
Write data
The write node requires a payload object like this one:
msg.payload = {
  // You bucket
  // Optional (it can be defined in the node credentials settings)
  bucket: 'myBucket',
  // Precision of timestamp
  // Optional
  // Can be `ns` (nanoseconds),
  //        `us` (microseconds),
  //        `ms` (milliseconds),
  //        `s` (seconds).
  // The default is `ns`
  // Note: if you set the `timestamp` field to `Date.now()`, you have to set the `precision` to `ms`
  precision: 'ms',
  // Data to send to InfluxDB
  // Can be an array of objects or only one object
  data: [
      measurement: 'machinerySensor',
      tags: {
        deviceId: 'gyh43',
        hardwareVersion: '1.0.2',
        softwareVersion: '2.5.1',
      fields: {
        temperature: 12,
        humidity: 46,
        vibrations: 18,
        batteryVoltage: 3.6
      timestamp: Date.now()
    // More data can be send here, simply re add an object
Example of the write node
Query data
The query node requires a topic string containing a Flux query.
msg.topic = 'from(bucket: "myBucket") |> range(start: -1h)';
You can write multiple lines queries like this:
msg.topic = [
  'from(bucket: "myBucket")',
  '  |> range(start: -1d, stop: now)',
  '  |> filter(fn: (r) => r._measurement == "machinerySensor")',
  '  |> filter(fn: (r) => r._field == "vibrations")',
  '  |> aggregateWindow(every: 1h, fn: mean)',
  '  |> yield(name: "mean")',
  '  |> aggregateWindow(every: 1h, fn: max)',
  '  |> yield(name: "max")',
].join('\n');
Example of the query node
Version: 1.0.4
Updated 3 years, 1 month ago
License: AGPL-3.0
8 in the last week
  • Stackhero-InfluxDB-v2-Server
  • Stackhero-InfluxDB-v2-query
  • Stackhero-InfluxDB-v2-write
  • stackhero
  • influxdb
  • influxdb-v2
