node-red-contrib-ssh-coco 0.2.4
A Node-RED node for running remote ssh commands and supports reconnection attempts. Based on https://github.com/yroffin/node-red-contrib-ssh
npm install node-red-contrib-ssh-coco
node-red-contrib-ssh-v2
Available on NPM as https://www.npmjs.com/package/node-red-contrib-ssh-coco
Based on node-red-contrib-ssh-coco to fix multiple issues with multiple ssh nodes and with processing multiple messages at the same time
Why?
I added this so I could turn on my linux HTPC via Alexa, triggering a WOL packet and then turn it off using SSH.
That's why SSH reconnection was important.
Changelog
  • fix multiple ssh nodes in one flow
  • fix processing of multiple messages at the same time
  • output of ssh node now contained the original message and the ssh session
Input: msg.payload has to contain the command.
Output: none
  • Ssh: ssh key path (optional but recommended)
  • Hostname: address of the target SSH server
  • Name: name of the node
  • Username: username of the target SSH server
  • Password: password of the target SSH server (set this if not using ssh key)
To-Do (help wanted)
  1. Add feature to reuse hosts/accounts instead of having to re-add every time
  2. Add output so that other nodes can consume the result
  3. Add option to consume more information(e.g. hostname) from other node
Version: 0.2.4
Updated 6 years, 8 months ago
Rating: 0.0
28 in the last week
  • ssh-client-v2
  • ssh
  • ssl
  • client
