node-red-contrib-sscma 0.3.6
Node-RED nodes for SSCMA
npm install node-red-contrib-sscma
Platform Node-RED
node-red-contrib-sscma is a Node-RED node component designed to facilitate the quick deployment of AI models through flow-based programming. This allows for seamless integration of AI model outputs with other devices, enabling smart automation and intelligent workflows.
  • AI Model Deployment: Easily deploy AI models using Node-RED's flow-based programming interface, making it accessible for users with minimal coding experience.
  • Device Integration: Connect the outputs of AI models to a wide range of devices and services, allowing for real-time automation and decision-making.
  • Flow-based Programming: Leverage the visual programming paradigm of Node-RED to design and deploy complex AI workflows quickly and efficiently.
  • Flexible Interconnection: Utilize AI-driven data to communicate and control various devices in an IoT ecosystem.
To install the package in Node-RED, run the following command:
Or install directly through the Node-RED interface.
Getting Started
  1. Open Node-RED and navigate to the flow editor.
  2. Drag the sscma node into your workspace.
  3. Configure the node by selecting the AI model you wish to deploy.
  4. Connect the node to other nodes for input/output to interact with devices or services.
  5. Deploy the flow to start processing AI data.
Example
Below is an example of how node-red-contrib-sscma can be used in a flow to connect an AI model’s output to a device:
[ Camera Node ] → [ Model Node ] → [ Output Device Node ]
This flow processes data using an AI model and sends the results to a connected device for further action.
This project is licensed under the Apache License 2.0.
Version: 0.3.6
Updated 11 months ago
Rating: 3.5 2
7 in the last week
  • camera
  • model
  • save
  • capture
  • stream
  • preview
  • sscma
  • sscma
  • vision ai
