node-red-contrib-sr-latch 1.0.0
Node-RED SR Latch (Set-Reset Flip-Flop) - memory element with set/reset control
npm install node-red-contrib-sr-latch
A Node-RED SR Latch (Set-Reset Flip-Flop) node - a memory element that holds its state until set or reset.
  • Set state to ON (true)
  • Reset state to OFF (false)
  • Toggle between states
  • Multiple input formats supported
  • Topic takes priority over payload
  • Configurable output mode (on change only / always)
  • Configurable initial state
How It Works
SET    ──┐     ┌── RESET
State: ──┴─────┴──────────────
         ON    OFF
The latch remembers its state until changed.
Property Description Options
Initial State State when Node-RED starts SET (ON) / RESET (OFF)
Output Mode When to send output On state change only / On every input
Input
The node accepts multiple input formats:
Via msg.topic (takes priority):
  • set or s - Set to ON
  • reset or r - Reset to OFF
  • toggle or t - Toggle state
Via msg.payload:
  • Boolean: true = SET, false = RESET
  • Number: 1 = SET, 0 = RESET
  • String: "set", "s", "on", "true", "1" = SET
  • String: "reset", "r", "off", "false", "0" = RESET
  • String: "toggle", "t" = TOGGLE
Output
  "payload": true,
  "action": "set",
  "previousState": false
payload Current state: true (ON) or false (OFF)
action Action performed: "set", "reset", or "toggle"
previousState State before the action
Examples
Basic Set/Reset
Input: {topic: "set"}   → Output: {payload: true, action: "set"}
Input: {topic: "set"}   → (no output - already set, no change)
Input: {topic: "reset"} → Output: {payload: false, action: "reset"}
Using Boolean Payload
Input: {payload: true}  → SET (ON)
Input: {payload: false} → RESET (OFF)
Toggle Mode
State: OFF
Input: {topic: "toggle"} → Output: {payload: true} (now ON)
Input: {topic: "toggle"} → Output: {payload: false} (now OFF)
Topic Priority
Input: {topic: "set", payload: false}
→ Output: {payload: true} (topic wins!)
Use Cases
  • Manual Override: Latch a manual mode flag until reset
  • Alarm Acknowledgment: Latch alarm state until operator acknowledges
  • Mode Selection: Toggle between operating modes
  • Start/Stop Control: Control a process with set/reset signals
  • Memory Element: Remember a state across flow executions
Node Status
Shows current state in the editor:
  • SET (ON) - Green dot, state is true
  • RESET (OFF) - Blue dot, state is false
Author
sr.rpo
MIT
Version: 1.0.0
Updated 8 months ago
119 in the last week
  • sr-latch
  • latch
  • sr-latch
  • flip-flop
  • set-reset
  • memory
  • state
