node-red-contrib-sqlbuilder 1.1.0
A "batteries included" SQL query builder for CockroachDB, MariaDB, MSSQL, MySQL, PostgreSQL, SQLite3, Oracle DB, and Amazon Redshift
npm install node-red-contrib-sqlbuilder
SQL - Module for Node-Red
Description
This is a "batteries included" SQL query builder for CockroachDB, MariaDB, MSSQL, MySQL, PostgreSQL, SQLite3, Oracle DB, and Amazon Redshift designed to be flexible, portable, and fun to use.
Building SQL manually is difficult and error prone, especially if you use multiple databases, as each has its own dialect.
This module is based on the excellent Knex.js project (https://knexjs.org), which allows to use JavaScript to generate the correct SQL.
Snapshot
SQLBuilder Basic Example
Example Queries
  • Select columns from table based on a where clause
query.select(["id", "first_name"]).from("users").where({
  • Multiple inserts
Wnat to insert multiple rows. Its easy, just add the objects to an array
query.insert([
    msg.user01,
    msg.user02
]).into('users')
  • Subquery
Example of a subquery in a WHERE IN clause
query
    .from("users")
    .whereNotIn("id",
        query
            .from("users_unsubscribed")
            .select(["user_id"]))
    .limit(1)
    .orderByRaw("RANDOM()")
    .select(["*"])
Full Query Documentation
Version: 1.1.0
Updated 1 year, 10 months ago
3 in the last week
  • sqlbuilder
  • sql
  • query-builder
  • knex
