node-red-contrib-splunk-hec 0.1.7
Node-RED node for sending events to Splunk HEC
npm install node-red-contrib-splunk-hec
Synopsis
The purpose of this project is to allow node-red to publish a node-red payload to Splunk HEC endpoints.
First Published: 19/03/2026
Latest Version: 0.1.7 as at 12/06/2026 Special thanks to Gary Croker for the passthrough request
Latest update
Fixed a bug introduced in previous version. Messge passed to Splunk removed any custom attributes injected at msg. level, only raw payload was passed. Now passes complete msg including custom attributes added to the message by other flow nodes.
Please see CHANGELOG.md for latest release notes, additions, bug fixes etc...
Motivation
Original Node created and published by gdziuba
Originally node lacked ability to name nodes or the saved configurations. Our organisation uses this extensively and needed a way to distinguish between multiple saved configs. This code has been further developed into the new node module to include these missing features plus some...
The easiest way to install is through the Node-Red Palette Manager that can be found in the menu on the top right hand corner of the Node-Red ui.
Manual install with npm
npm install -g node-red-contrib-splunk-hec
Install from source
From github: Navigate to the your node_modules directory in your Node-RED instance. eg. cd ~/.node-red/node_modules
git clone https://github.com/IcyWorks/node-red-contrib-splunk-hec.git
cd splunk-hec
npm install
Example:
Import example flow:
splunk-hec_0.1.7_example.json
Setup
Splunk HTTP Event Collector Documentation Click this link with your mouse wheel to open in a new tab
Node-RED Functions for converting msg to correct structure for Metric Event Collector.
Single value MQTT payload message to Metric structure:
var o = msg.payload;
var v = msg.topic;
msg.payload = {};
msg.payload.fields = {};
msg.payload.fields._value = o;
msg.payload.fields.metric_name= v;
Single value with dimensions enabled :
var v = msg.topic;
msg.payload = {};
msg.payload.splunkdims = true;
msg.payload.fields.dimension1= "value1";
Version: 0.1.7
Updated 5 months, 3 weeks ago
Rating: 4.0 1
178 in the last week
  • splunk-hec-config
  • splunk-hec
  • splunk
  • HTTP Event Collector
  • HEC
  • hec
