node-red-contrib-speed-test 0.1.2
Test your download speed using speed test
npm install node-red-contrib-speed-test
node-red-contrib-fast-test Build Status
Test your download speed using speedtest.net
Ensure you have Node.js version 4+ installed. Then run the following:
Currently, no configuration is needed to use this node. An input is required to fire the speed test; any input will trigger a new test. After the test is complete, the results can be found in the output, msg.payload.speedResults.
Example
Currently, I have a speed test on a 15 minute repeat trigger. After the test is complete, the output is logged to a file.
	"id": "7fdc1b50.b6ce74",
	"type": "tab",
	"label": "Flow 2"
	"id": "6ecabfce.dab84",
	"type": "inject",
	"z": "7fdc1b50.b6ce74",
	"name": "Refresh Timer",
	"topic": "",
	"payload": "",
	"payloadType": "date",
	"repeat": "900",
	"crontab": "",
	"once": true,
	"x": 144.5,
	"y": 132,
		["662adda6.ab48c4"]
	"id": "662adda6.ab48c4",
	"type": "speed-test",
	"x": 341.5,
	"y": 191,
		["3c6c82c5.03230e"]
	"id": "3c6c82c5.03230e",
	"type": "file",
	"name": "Logger",
	"filename": "/home/pi/log/speed-test.log",
	"appendNewline": true,
	"createDir": true,
	"overwriteFile": "false",
	"x": 533.5,
	"y": 250,
Related
  • speedtest.net - Test your internet connection speed and ping using speedtest.net
MIT © Luke Davis
Version: 0.1.2
Updated 9 years, 10 months ago
11 in the last week
  • speed
