node-red-contrib-sparkml 1.0.0
NodeRED Extension Pack for SparkML
npm install node-red-contrib-sparkml
This is a Node-RED extension pack and contains a set of nodes which offer Spark Dataframe, SQL and machine learning functionalities. All nodes have a python/pyspark core.
Allows Drag & Drop Machine Learning with Spark. Provides Visual Interface.
Drag Drop Spark ML
Functionalities
This project is a WIP, and I am planning to add more nodes - as many as are available in Spark Transformers and Estimators.
Feature Extractors
  • TF-IDF
  • Word2Vec
  • CountVectorizer
  • FeatureHasher
Feature Transformers
  • Tokenizer
  • StopWordsRemover
  • n-gram
  • Binarizer
  • PCA
  • StringIndexer
  • IndexToString
  • OneHotEncoderEstimator
  • VectorIndexer
  • SQLTransformer
  • VectorAssembler
Classification Algorithms
  • Decision Tree Classifier
  • Logistic Regression
  • Gradient-boosted Tree Classifier
  • Multilayer Perceptron
  • Random Forest Classifier
  • Support Vector Machines
  • k-Nearest Neighbour Classifier
Clustering Algorithms
  • K-Means Clustering
  • Latent Dirichlet allocation (LDA)
Pre requisites
Be sure to have a working installation of Node-RED.
Install python and the following libraries:
  • Python 3.6.4 or higher accessible by the command 'python' (on linux 'python3')
  • PySpark
To install the latest version use the Menu - Manage palette option and search for node-red-contrib-sparkml, or run the following command in your Node-RED user directory (typically ~/.node-red):
npm i node-red-contrib-sparkml
These flows create a dataset, train a model and then evaluate it. Models, after training, can be use in real scenarios to make predictions.
There is an example flow and a test dataset available in the 'test' folder.
Tip: You can run 'node-red' (or 'sudo node-red' if you are using linux/mac) from the folder '.node-red/node-modules/node-red-contrib-sparkml' to avoid confusion.
Example Deployment Deployment
Contributors Welcome
I am looking for contributors! Feel free to open issues directly on github or email me for any questions, suggesting features or general feedback!
Version: 1.0.0
Updated 5 years, 6 months ago
Rating: 5.0 3
5 in the last week
  • create sparkml dataset
  • load sparkml dataset
  • tokenize column
  • calculate term frequencies
  • calculate inverse document frequency
  • string indexer
  • vector indexer
  • vector assembler
  • sql transformer
  • decision tree classifier
  • gradient boosted tree classifier
  • logistic regression
  • multilayer perceptron classifier
  • random forest classifier
  • export predictions as csv
  • machine learning
  • ml
  • sparkml
  • classification
  • regression
  • clustering
  • outlier
  • bigdata
  • spark
  • anomaly
  • detection
