node-red-contrib-sound-level 1.0.0
Node-RED node for sound level estimates: dB at a distance (inverse-square law with air absorption), distance for a target level, and combined levels of several sources.
A Node-RED node for quick sound level estimates in a free field:
- Level at distance: dB at a distance from a level known at a reference distance (inverse-square law), with an optional air absorption term.
- Distance for target level: how far away a source drops to a given dB.
- Combine levels: the total of several incoherent sources (two equal sources add about 3 dB).
Useful for noise dashboards, siren or horn audibility checks, sensor post-processing and "how loud is it over there?" questions in home automation flows. The math comes from the tested trainhorn-calc package.
From the Node-RED palette manager, search for node-red-contrib-sound-level, or run in your Node-RED user directory (usually ~/.node-red):
npm install node-red-contrib-sound-level
Requires Node-RED 3.0 or later and Node.js 18.3 or later.
The node is in the function category as sound level.
Level at distance
Send either a number (the distance; the other values come from the node settings) or an object:
{ "sourceDb": 150, "refDistance": 10, "distance": 100, "unit": "ft" }
Output (msg.payload):
{ "mode": "level", "sourceDb": 150, "refDistance": 10, "distance": 100, "unit": "ft", "absorptionDbPerKm": 0, "levelDb": 130 }
Formula: L = sourceDb - 20*log10(distance/refDistance) - absorptionDbPerKm * (d_m - ref_m) / 1000.
Send a number (the target dB) or { sourceDb, refDistance, targetDb, unit, absorptionDbPerKm }. The output adds distanceForTarget in the same unit. For 150 dB at 10 ft, 90 dB is reached at 10,000 ft without absorption, and closer with it.
Combine levels
Send an array of dB values, e.g. [100, 100], or { "levels": [100, 100] }. The output adds combinedDb (103.01 here).
Settings and overrides
| Setting | Payload property | Default |
| Mode | mode (level, distance, combine) |
level |
| Source dB | sourceDb |
150 |
| Ref. distance | refDistance |
10 |
| Distance | distance |
from payload |
| Target dB | targetDb |
from payload |
| Unit | unit (ft or m) |
ft |
| Air absorption, dB/km | absorptionDbPerKm |
0 |
| Decimals | (node only) | 1; blank means no rounding |
Payload properties win over node settings. Other payload properties are passed through unchanged.
Typical air absorption at 10 °C and 70 % RH: about 1.9 dB/km at 500 Hz and 3.7 dB/km at 1 kHz.
Errors
Invalid input (missing values, a distance of 0 or less, an unknown unit, non-numbers, an empty list) is reported with done(err), so a catch node can handle it, and the node shows a red status.
Example
Import Menu > Import > Examples > node-red-contrib-sound-level > sound-level-basics. It shows all three modes with inject and debug nodes.
Notes
The results are free-field estimates, not measurements. Ground, buildings, barriers, wind and temperature gradients change real levels. To try the same calculation in a browser, see the decibel distance calculator.
Tests
npm install
npm test
The tests use node-red-node-test-helper and mocha and cover all modes, the example flow and invalid input.
MIT, see LICENSE.
