node-red-contrib-sony-projector 0.0.1
Node Red Node for controlling Sony Projectors via PJ Talk
Tested with
- VPL-VW270ES
Also See https://github.com/vokkim/sony-sdcp-com for other supported Projectors since this Project relys on that library.
npm install node-red-contrib-sony-projector
Projector
- Enable Remote Management
- Define Static IP (Recommended)
- Configure PJ Talk in in Web Interface (Community = SONY, Port, Host Address = Node Red Server Address)
Node Red
You need to specifiy the following settings in the Node configuration:
- projectorIp: IP Address of the Projector
- projectorPort: Port of the Projects SDCP Server. Default: 53484 - can be configured in the Projector Web Interface
You can send the following commands as a text string in msg.payload
- getpowerstate (returns: OFF, WARMING, ON, COOLING)
- on
- off
- more to come
See this example flow to see the usage of all commands:
Credits
Thanks to vokkim for providing https://github.com/vokkim/sony-sdcp-com as the basis library for this Project.
Contribute
Issues and pull requests welcome
MIT
