node-red-contrib-soma-smartblinds2 0.3.2
NodeRed node for Soma smart blinds 2.
npm install node-red-contrib-soma-smartblinds2
node-red-contrib-soma-blinds2
NodeRed node for Soma Smart Blinds 2
What is this node ?
This is a node for Node-Red to control Soma smart blinds 2 via Bluetooth (BLE) directly. No bridge or additional hardware/software is necessary.
It is heavily based on the work by @andersonshatch , https://github.com/andersonshatch/soma-ctrl
The SOMA smart shade device needs to be configured with the SOMA app before connecting.
Scan for the devices with the scan button. Look for devices with the name S or RISE to identify the id.
The Node will connect and receive status messages like position, battery or connection
Commands
The Node accepts the following commmands;
  • moveTo (0-100)
  • moveUp
  • moveDown
  • stop
  • getPosition
  • getBattery
  • identify
Position
The device will try to move to the exact position but will stop at approximation. Position will be correctly reported.
Changes;
  • 0.3.2, stability fixes. Better reconnect performance. Removed config scanning options. Manual input of Bluetooth ID is now required.
  • 0.3.1, added getBattery command to instantly retrieve the current battery value
  • 0.3.0, Added Charging and panel reporting.
Bluetooth
  • Compatible Bluetooth 5.0 Zephyr HCI-USB adapter (you need to add BLUETOOTH_HCI_SOCKET_USB_VID and BLUETOOTH_HCI_SOCKET_USB_PID to the process env)
  • Compatible Bluetooth 4.0 USB adapter
Distance is important. Make sure the bluetooth signal is strong enough.
Running without root/sudo (Linux-specific, not always necessary).
Run the following command:
sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
This grants the node binary cap_net_raw privileges, so it can start/stop BLE advertising.
Note: The above command requires setcap to be installed. It can be installed the following way:
  • apt: sudo apt-get install libcap2-bin
  • yum: su -c 'yum install libcap2-bin'
Version: 0.3.2
Updated 3 years, 4 months ago
  • soma-smartblinds2
  • soma
  • smart blinds
