node-red-contrib-solution-engine 0.9.4
Node-RED nodes for Solution Engine and MTConnect integration
npm install node-red-contrib-solution-engine
Node-RED nodes for interacting with Solution Engine and MTConnect devices.
Source
Full source is available in GitHub
Install the package by first navigating to the local node-RED folder.
On Windows this will likely be
cd C:\Users\<my-user-name>\.node-red
npm install node-red-contrib-your-node
or on Linux
Or for development:
cd /path/to/node-red-contrib-solution-engine
npm link
npm link node-red-contrib-solution-engine
Restart Node-RED after installation.
MTConnect Data Item (Read)
Reads a specific data item value from an MTConnect endpoint. Supports both Solution Engine and generic MTConnect brokers.
Configuration:
  • Host: IP address or hostname (e.g., 192.168.5.90, mtconnect.mazakcorp.com)
  • Port: MTConnect port (default: 5000)
  • Path: Optional path for generic brokers (leave empty for most cases)
  • Data Item ID: The dataItemId to query (e.g., EngineInfo.EngineID)
Input:
  • msg.payload: Any value (triggers the read)
  • msg.host: (optional) Override configured host
  • msg.port: (optional) Override configured port
  • msg.path: (optional) Override configured path
  • msg.dataItemId: (optional) Override configured data item ID
Output:
  • msg.payload: The data item value
  • msg.dataItemId: The data item ID that was queried
  • msg.timestamp: MTConnect timestamp
  • msg.sequence: MTConnect sequence number
  • msg.name: Friendly name of the data item
Broker Detection:
The node automatically detects whether the target is a Solution Engine or generic MTConnect broker:
  • Solution Engine: Uses /api/v6/mtc/current
  • Generic broker: Uses /{path}/current or /current
The broker type is cached after first detection for performance.
Examples:
Solution Engine:
Host: 192.168.5.90
Port: 7200
Path: (empty)
Data Item ID: EngineInfo.EngineID
→ URL: http://192.168.5.90:7200/api/v6/mtc/current
→ Returns: "DCA6326DA159"
Mazak Demo Broker:
Host: mtconnect.mazakcorp.com
Port: 5610
Path: (empty)
Data Item ID: xpm
→ URL: http://mtconnect.mazakcorp.com:5610/current
→ Returns: "UNAVAILABLE"
Important: Data item IDs are case-sensitive. Use exact case from the MTConnect XML (e.g., EngineInfo.EngineID not EngineInfo.EngineId).
Engine Set Data Item (Write)
Sets a data item value on a Solution Engine device.
Configuration:
  • Host: IP address or hostname (e.g., 192.168.5.90)
  • Port: Solution Engine port (default: 7200)
  • Data Item ID: The dataItemId to set (e.g., EngineInfo.Location.PostalCode)
Input:
  • msg.payload: The value to set (string or number)
  • msg.value: (alternative to payload) The value to set
Output:
  • msg.payload.success: true if successful, false if error
  • msg.payload.dataItemId: The data item ID that was set
  • msg.payload.value: The value that was sent
  • msg.payload.statusCode: HTTP status code
  • msg.response: Server response (if any)
Endpoint:
PUT http://{host}:{port}/api/v6/agent/data
Request Body (XML):
<DataItems>
    <DataItem dataItemId="EngineInfo.Location.PostalCode">
        <Value>12345</Value>
    </DataItem>
</DataItems>
Example:
Set a postal code:
msg.payload = "12345";
// Data Item ID configured as: EngineInfo.Location.PostalCode
// → Sends PUT request with XML body
// → Returns: { success: true, dataItemId: "...", value: "12345", statusCode: 200 }
Note: This node only works with Solution Engine devices, not generic MTConnect brokers.
Status Indicators
Both nodes show visual status indicators:
  • Blue dot: Request in progress
  • Green dot: Success
  • Yellow ring: Data item not found (read node only)
  • Red ring: Error occurred
Flow Examples
Basic Read Flow
[Inject] → [MTConnect Data Item] → [Debug]
Inject: Every 5 seconds
MTConnect Data Item:
  Host: 192.168.5.90
  Port: 7200
  Data Item ID: EngineInfo.CPUTemp
Debug: msg.payload
Read and Write Flow
[Inject] → [Change] → [Engine Set Data Item] → [Delay] → [MTConnect Data Item] → [Debug]
Inject: Manual trigger
Change: Set msg.payload = "New Value"
Engine Set Data Item:
  Host: 192.168.5.90
  Port: 7200
  Data Item ID: MyComponent.MyValue
Delay: 1 second
  Host: 192.168.5.90
  Port: 7200
Debug: msg.payload
Multiple Hosts
[Inject] → [MTConnect Data Item (Engine 1)] → [Debug]
           [MTConnect Data Item (Engine 2)] → [Debug]
           [MTConnect Data Item (Mazak)] → [Debug]
Each node can target a different host. Broker type is cached per host:port combination.
Troubleshooting
"Data item not found"
  1. Check case sensitivity: Data item IDs are case-sensitive. Verify the exact case in the MTConnect XML response.
  2. Verify the data item exists: Open http://{host}:{port}/api/v6/mtc/current in a browser and search for the dataItemId attribute.
  3. Check broker detection: Look at Node-RED logs to see which URL is being used.
Wrong URL being used
The broker type is cached in memory. Restart Node-RED to clear the cache if you changed the configuration.
Connection errors
  1. Verify the host and port are correct
  2. Check network connectivity: curl http://{host}:{port}/current
  3. Check firewall settings
Logging
Both nodes log useful debug information. View logs in the Node-RED console:
Detecting broker type for 192.168.5.90:7200...
Broker detection complete: isSolutionEngine=true
Fetching from: http://192.168.5.90:7200/api/v6/mtc/current
PUT to http://192.168.5.90:7200/api/v6/agent/data with body: <DataItems>...
MIT
Author
Chris Tacke - LECS Energy
  • solutionengine
  • mtconnect
  • manufacturing
  • lecenergy
  • lecs
Version: 0.9.4
Updated 11 months, 2 weeks ago
5 in the last week
  • mtconnect-dataitem
  • engine-set-dataitem
  • node-red-contrib
  • solutionengine
  • mtconnect
  • manufacturing
  • lecenergy
  • lecs
