node-red-contrib-solidity 1.0.0
node-red-contrib-solidity ===================
npm install node-red-contrib-solidity
node-red-contrib-solidity is a package that bundles a set of Node-RED nodes that can be used to perform solidity operations
Currently, there are five nodes implemented:
  • node-solidity-compiler: compilation process of the solidity code
  • node-solidity-compiler-from-bpmn: compilation process from bpmn code to solidity code
  • node-solidity-deploy: deployment process of the solidity code
  • node-solidity-interaction: interaction process with a smart contract already deployed in a blockchain network
  • node-solidity-interaction-parameter: interaction process with a smart contract already deployed in a blockchain network by specifying the parameters in the node itself
To install the package, just run the following command in your Node-RED user directory (normally ~/.node-red):
git clone https://github.com/JesusRosaB/node-red-contrib-solidity.git
Just like any Node-RED node, simply drag the desired node and drop it on the main canvas/flow. However, as a requirement, each msg containing the input data to the nodes in this package must be in msg.payload. In addition, all results generated as a consequence of using these nodes will also be found in the msg object, concretely, in msg.payload.
Examples
Below, you can find several simple examples (JSON code of flows). To use it, you just need to import the streams into node-red. These examples are a basic implementation of the nodes presented in this package to see their operation and requirements.
[{"id":"f6f2187d.f17ca8","type":"tab","label":"Solidity compilation flow","disabled":false,"info":""},{"id":"c6050446.7be55","type":"inject","z":"f6f2187d.f17ca8","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"contract Storage { uint256 number;    function store(uint256 num) public {        number = num;    }    function retrieve() public view returns (uint256){        return number;    }}","payloadType":"str","x":390,"y":220,"wires":[["3544a7aa.87a66"]]},{"id":"dc5c0dd2.fb4368","type":"debug","z":"f6f2187d.f17ca8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":970,"y":220,"wires":[]},{"id":"3544a7aa.87a66","type":"solidity-compiler","z":"f6f2187d.f17ca8","name":"","x":680,"y":220,"wires":[["dc5c0dd2.fb4368"]]}]
Solidity compilation flow example
[{"id":"dee25cc01a3772c9","type":"tab","label":"Solidity deployment flow","disabled":false,"info":""},{"id":"85c9d6ec3030b2dd","type":"smartcontract-config","name":"Storage","bytecode":"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","abi":"[{\"inputs\":[],\"name\":\"retrieve\",\"outputs\":[{\"internalType\":\"uint256\",\"name\":\"\",\"type\":\"uint256\"}],\"stateMutability\":\"view\",\"type\":\"function\"},{\"inputs\":[{\"internalType\":\"uint256\",\"name\":\"num\",\"type\":\"uint256\"}],\"name\":\"store\",\"outputs\":[],\"stateMutability\":\"nonpayable\",\"type\":\"function\"}]","scaddress":""},{"id":"6318be4cc8cce212","type":"solidity-deploy","z":"dee25cc01a3772c9","name":"","config":"","smartcontract":"85c9d6ec3030b2dd","parametersList":[],"x":550,"y":240,"wires":[["03743034d24bcd73"]]},{"id":"03743034d24bcd73","type":"debug","z":"dee25cc01a3772c9","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":880,"y":240,"wires":[]}]
Solidity deployment flow example
[{"id":"09669cfa67103161","type":"tab","label":"Solidity interaction flow","disabled":false,"info":""},{"id":"85c9d6ec3030b2dd","type":"smartcontract-config","name":"Storage","bytecode":"6080604052348015600e575f80fd5b506101438061001c5f395ff3fe608060405234801561000f575f80fd5b5060043610610034575f3560e01c80632e64cec1146100385780636057361d14610056575b5f80fd5b610040610072565b60405161004d919061009b565b60405180910390f35b610070600480360381019061006b91906100e2565b61007a565b005b5f8054905090565b805f8190555050565b5f819050919050565b61009581610083565b82525050565b5f6020820190506100ae5f83018461008c565b92915050565b5f80fd5b6100c181610083565b81146100cb575f80fd5b50565b5f813590506100dc816100b8565b92915050565b5f602082840312156100f7576100f66100b4565b5b5f610104848285016100ce565b9150509291505056fea26469706673582212204e7814d536e8d27a66caa4b21d2184bb401ae1858294ceeeceaac1080f84f45f64736f6c634300081a0033","abi":"[{\"inputs\":[],\"name\":\"retrieve\",\"outputs\":[{\"internalType\":\"uint256\",\"name\":\"\",\"type\":\"uint256\"}],\"stateMutability\":\"view\",\"type\":\"function\"},{\"inputs\":[{\"internalType\":\"uint256\",\"name\":\"num\",\"type\":\"uint256\"}],\"name\":\"store\",\"outputs\":[],\"stateMutability\":\"nonpayable\",\"type\":\"function\"}]","scaddress":""},{"id":"a8a10ad7e16b0328","type":"inject","z":"09669cfa67103161","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"[ { \"value\": 123 } ]","payloadType":"str","x":470,"y":260,"wires":[["1664219ff9672a55"]]},{"id":"815ce91101a82908","type":"debug","z":"09669cfa67103161","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1030,"y":260,"wires":[]},{"id":"1664219ff9672a55","type":"solidity-interaction","z":"09669cfa67103161","name":"","config":"","smartcontract":"","scnamefunction":"store","ispurefunction":false,"x":750,"y":260,"wires":[["815ce91101a82908"]]}]
Solidity interaction flow example
[{"id":"f6f2187d.f17ca8","type":"tab","label":"Solidity interaction with parameters flow","disabled":false,"info":""},{"id":"85c9d6ec3030b2dd","type":"smartcontract-config","name":"Storage","bytecode":"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","abi":"[{\"inputs\":[],\"name\":\"retrieve\",\"outputs\":[{\"internalType\":\"uint256\",\"name\":\"\",\"type\":\"uint256\"}],\"stateMutability\":\"view\",\"type\":\"function\"},{\"inputs\":[{\"internalType\":\"uint256\",\"name\":\"num\",\"type\":\"uint256\"}],\"name\":\"store\",\"outputs\":[],\"stateMutability\":\"nonpayable\",\"type\":\"function\"}]","scaddress":""},{"id":"d99656b6.50cfd","type":"solidity-interaction-parameters","z":"f6f2187d.f17ca8","name":"","config":"","smartcontract":"85c9d6ec3030b2dd","scnamefunction":"store","ispurefunction":false,"parametersList":[{"value":"123"}],"x":580,"y":260,"wires":[["dccacabd.9f5458"]]},{"id":"dccacabd.9f5458","type":"debug","z":"f6f2187d.f17ca8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":960,"y":260,"wires":[]}]
Solidity interaction with parameters flow example
node-red-contrib-solidity is available under Creative Commons Attribution-ShareAlike 4.0 International (CC BY-SA 4.0) License. See the LICENSE file for more info.
Version: 1.0.0
Updated 2 years, 6 months ago
License: Creative Commons Attribution-ShareAlike 3.0 Unported (CC BY-SA 3.0)
  • blockchain-config
  • smartcontract-config
  • solidity-compiler
  • solidity-compiler-from-bpmn
  • solidity-deploy
  • solidity-interaction
  • solidity-interaction-parameters
  • blockchain
  • solidity
