node-red-contrib-solar-power-forecast-plus 2.0.6
A node-red node to forecast the output of a solar system at a specified time with dynamic inputs.
npm install node-red-contrib-solar-power-forecast-plus
Based on [node-red-contrib-solar-power-forecast](https://flows.nodered.org/node/node-red-contrib-solar-power-forecast].
Thanks to Dean Cording.
A Node Red node to forecast the power output of a solar system under ideal conditions at a specified time.
Input message payload contains the timestamp for solar power output to be calculated at. Can also receive on object the parameters for dynamic requests.
Uses the suncalc to calculate the current sun position. Power forecast is adjusted for panel tilt, orientation, altitude, panel area, number of panels and panel efficiency.
  • Name
  • Lat & lon is the location of the solar system.
  • Tilt is degrees from the horizontal.
  • Orientation is the bearing in degrees from North.
  • Altitude is in metres above sea level.
  • Area is the surface of a single panel in m^2.
  • Number is the number of panels in the system.
  • Efficiency is the conversion efficiency of the panel under ideal conditions.
Input
  • msg.payload can contains
  • tilt contains the Tilt for the calculation.
  • orientation contains the Orientation for the calculation.
Output
msg.payload contains:
  • timestamp: Timestamp of calculation
  • powerforecast: Forecast of electrical power generated by the system under ideal conditions.
See PV Education for details of calculation.
Version: 2.0.6
Updated 8 years, 8 months ago
Rating: 3.0 1
31 in the last week
  • solar power forecast plus
  • solar
  • sun
  • power
  • dynamic parameters
