node-red-contrib-sok 1.0.4
Simple Node-RED BLE reader for SOK smart batteries.
npm install node-red-contrib-sok
Strict TypeScript Node.js library, CLI, and Node-RED nodes for SOK smart batteries over BLE.
The current implementation targets the BLE protocol seen in captures/SOK Batterie SK12V324PH00057.pklg:
  • advertised name: SK12V314XXXXXXX
  • service UUID: fff0
  • notify characteristic: fff1
  • write characteristic: fff2
  • payload protocol: Modbus RTU read-holding-register frames over BLE notifications
Library
The package exports a typed ESM API from dist/index.js:
  • discoverBatteries(options) returns matching BLE devices
  • readBatteries(options) discovers and reads zero, one, or many devices
  • readBatteryDevice(device, options) reads one discovered device
  • connectBatteryReaders(options) discovers and connects once, then returns persistent readers with read() and disconnect()
  • shutdownBluetooth() stops active BLE sessions
Read output is always an array at the CLI and Node-RED layer. Each reading contains compact device metadata, a timestamp, and decoded data. Raw register maps and Modbus frames are not included in public JSON output.
For repeated reads, keep the BLE session open and only issue new register requests:
import { connectBatteryReaders } from 'node-red-contrib-sok';
const readers = await connectBatteryReaders({
  deviceName: 'SK12V314XXXXXXX',
  reads: 'telemetry'
try {
  const reading = await readers[0].read();
  console.log(reading.decoded);
} finally {
  await Promise.all(readers.map((reader) => reader.disconnect()));
  • sok-battery-device: config node for the battery BLE target
  • sok-battery-get: input node that reads telemetry, limits, and status
Use the config node's search button to discover SOK batteries from the Node-RED editor. Select one exact advertised device name, or keep "All discovered devices".
The output is placed in msg.payload as an array with zero, one, or multiple readings.
CLI
npm install
npm run build
npm run discover
npm run get
Useful options:
node ./bin/sok-battery.js discover --name-prefix SK
node ./bin/sok-battery.js get --reads telemetry
node ./bin/sok-battery.js get SK12V314XXXXXXX
node ./bin/sok-battery.js get SK12V314XXXXXXX --interval 5
node ./bin/sok-battery.js get --bluetooth bluez --debug
get --interval 5 keeps the BLE session open and reads every five seconds until stopped.
Bluetooth backends:
  • auto: uses BlueZ on Linux when available, otherwise noble
  • bluez: uses Linux BlueZ over D-Bus, useful on devices where noble would require extra privileges
  • noble: uses @abandonware/noble, useful for macOS smoke tests
Development
npm run build
npm run lint
npm test
npm run check
Version: 1.0.4
Updated 6 months, 1 week ago
537 in the last week
  • sok-battery-get
  • sok
  • battery
  • bluetooth
  • ble
  • modbus
