node-red-contrib-socrata 0.0.7
Node-RED node to connect to Socrata Open Data API endpoints. Provides a convenient node to easily create and test SoQL queries.
npm install node-red-contrib-socrata
Refer to the Info tab of the node for full details.
The node itself provides a more convenient access to the SoQL queries to your Socrata endpoint. Depending on your usage scenario additional logic/flow control nodes will be needed up/downstream to manage queries and the resulting data.
Nodes such as node-red-contrib-splitter will come in especially handy to process the potentially large dataset from a Socrata query.
Basic Examples
todo: basic examples datasets
todo: examples for dealing with larger datasets
FAQ
  1. Do I need to have an app token?
You'll need to sign up for a Socrata developer account via your open data provider to generate an app token. The app token gives you unthrottled access to the data endpoint (but as the Socrata Developers Portal says, don't be a jerk).
  1. Why do requests take such a long time?
The underlying HTTP/S request is asynchronous, and shouldn't lock up the rest of Node-RED. As with any SQL-like query, it is up to you to write efficient queries to get the data you need. Use the $limit and $offset parameters, along with control logic before the Socrata node, to manage large dataset queries.
Further Resources
SODA Developers Portal
Credits
Copyright (c) 2018 Chuan Khoo
Please refer to LICENSE for open-source licensing details & attribution.
Version: 0.0.7
Updated 8 years, 9 months ago
11 in the last week
  • socrata-config
  • Socrata
  • socrata
  • open
  • data
  • API
  • SODA
