node-red-contrib-socketio-extended 1.0.1
Implementation of a SocketIO Sever for Node-RED
npm install node-red-contrib-socketio-extended
Implementation for Node-RED of the popular Socket.IO.
It is forked from node-red-contrib-socketio since the original package seems not to be maintained anymore. Therefor some pending pull requests from the original repo are already implemented in this one.
  • CORS support
To install node-red-contrib-socketio use this command
npm i node-red-contrib-socketio-extended
Composition
The Socket.IO implementation is made with
  • 1 configuration Node that holds the server definitions and the user can decide to bind the SocketIO server on the Node-RED port or bind it to another port
  • 1 input node where the user adds all the topics in which they are interested
  • 1 output node that sends the data received into msg.payload
  • 1 node to join a Socket IO room
  • 1 node to leave a Socket IO room
To see an example usage go to Example Chat App
MIT
Thanks
Thank to:
  • @nexflo for translating the comments in English and for pre-sending control data
  • @bimalyn-IBM for implementing rooms
  • @essuraj for implementing rooms listing node
  • @cazellap for adding compatibility to socketIO 3.0
Version: 1.0.1
Updated 4 years, 1 month ago
5 in the last week
  • socketio-config
  • socketio-in
  • socketio-out
  • socketio-join
  • socketio-leave
  • socketio-rooms
