node-red-contrib-smsgora 1.0.0
Node-RED nodes for SMS Gora: send and receive SMS through your own Android phones, with delivery reports and signed webhooks.
Node-RED nodes for SMS Gora, the SMS gateway that sends and receives texts through your own Android phones.
Send SMS from any flow (alerts from sensors, Home Assistant, PLCs, servers, forms) and react to incoming SMS and delivery reports. There's no sender ID registration and no per-message fee from us: your mobile operator bills the texts like any SMS.
In Node-RED: Menu → Manage palette → Install, search for node-red-contrib-smsgora.
Or from your Node-RED user directory (usually ~/.node-red):
npm install node-red-contrib-smsgora
Needs Node-RED 3.0+ and Node.js 18+. No other dependencies.
Setup
- In the SMS Gora dashboard, link an Android phone (install the SMS Gora app and scan the QR code).
- Create an API key under SMS Gora → API keys (it starts with
sgk_). - Add any SMS Gora node to a flow, open it, and create an SMS Gora account (config node) with the key.
sms gora send
Sends an SMS.
msg.payload: the text (or set Message in the node)msg.to: one or more numbers in international format, comma separated or an array, up to 1,000 (or set To)- optional
msg.deviceId,msg.simSlot(0 = SIM 1, 1 = SIM 2),msg.scheduleAt
Output: msg.payload = { message_ids: [...] }.
sms gora api
Calls any endpoint of the SMS Gora API and returns its data: for example GET /messages/1873 (delivery status), POST /messages/1873/cancel, GET /received-sms?limit=50, GET /devices, GET /account. msg.method, msg.path and msg.payload (JSON body) override the node settings.
sms gora webhook
Receives incoming SMS and sent, delivered or failed reports, and checks the X-SmsGora-Signature (HMAC-SHA256) so nobody else can trigger your flow.
[http in POST /smsgora] → [sms gora webhook] → your flow
↘ output 2 → [http response]
Add https://<your-node-red>/smsgora in SMS Gora → Webhooks, paste the secret into the node, and optionally filter events (sms.received, sms.sent, sms.delivered, sms.failed). msg.topic is the event name; msg.payload.data.from and msg.payload.data.message hold an incoming SMS.
Errors from the send and api nodes can be caught with a catch node: msg.error holds status, message, errors and retryAfter.
Example
Import Menu → Import → Examples → node-red-contrib-smsgora → send-sms: an inject node that sends a test SMS, and a webhook flow that logs incoming SMS.
More from Tekservix
- WAservix WhatsApp API Gateway: WhatsApp from your own number, also for Node-RED (
node-red-contrib-waservix) - AI Sales Agent: answers customers on WhatsApp and SMS using your website's content
- Website to App: turn your website into Android and iOS apps
- SMS Gora libraries for 12 languages and n8n nodes: github.com/TekservixHQ
MIT
