node-red-contrib-smithtek-schedule 1.8.3
Smithtek 24-channel irrigation scheduler with Smithtek.cloud integration
npm install node-red-contrib-smithtek-schedule
smithtek-irrigation-scheduler
SmithTek format
Install the smithtek-irrigation-scheduler using the Node-RED Palette Manager, or place it manually into your Node-RED ~/.node-red/nodes directory and restart Node-RED.
The smithtek-irrigation-scheduler node is designed to work in conjunction with the Schedule Widget inside Smithtek.cloud. It retrieves schedule data from the cloud and controls up to 24 outputs (stations) based on that data. it uses the PassPort CPU clock, so even during network outages it will use the onboard RTC to maintain the correct time, If you Change your PassPort local time using the RTC node it will alter the scheduling working time. you must make sure the times selected are in line with your application needs. The configuration is stored in the PassPort so even after power cycles it will load the last config and continue. This is good for poor network coms and/or unstable power systems.
Each schedule created in the cloud matches an output in Node-RED:
  • The first schedule controls output1
  • The second schedule controls output2
  • … and so on, up to output24
SmithTek format
Setup smithtek-irrigation-scheduler
  1. Drag the smithtek-irrigation-scheduler node into your Node-RED flow
  2. Configure the following:
    • Device Token – your secure device API token, located in /devices
    • Variable ID – This is the ID for a single variable located in /devices/variable
    • Update Frequency – polling rate (10 to 60 seconds only)
    • Site Name – optional label shown on dashboard widgets
This node will periodically check for updated schedule via the " update frequency" from the cloud and control each output according to:
  • ON mode: forces the output to ON (1) continuously
  • OFF mode: disables the output; no messages will be sent
  • Auto Schedule: evaluates time/day logic and turns ON or OFF as required
SmithTek format
Message Output Logic
To avoid overloading RF or telemetry networks, the node only sends output messages when a state changes.
  • If mode is OFF – no messages will pass through for that output
  • If mode is ON or Auto Schedule:
    • The node will send a message only when the output changes state
    • This reduces wasted transmissions and keeps things efficient
Node Display
The node will display a live status summary directly beneath it in the Node-RED editor showing the mode and state of each output (e.g., output1: Auto Schedule = 1).
This allows for quick visual feedback without opening debug panels.
Smithtek.cloud Integration
This node interfaces with Smithtek.cloud only to retrieve schedule data.
To read/write any other variables such as tank levels, pressures, switches, or alarms, use the standard smithtek in and out nodes
🟡 The scheduler system uses a single variable to manage all schedule data. This helps conserve data usage, but make sure you have an active Smithtek.cloud plan with sufficient data transmission allowance.
Smithtek.cloud Dashboard Usage
Logon at www.smithtek.cloud
The Smithtek Schedule Configurator widget is used to configure all scheduling directly from the Smithtek.cloud dashboard.
SmithTek format
Step-by-step:
  1. Name the Site:
    At the top of the widget, enter a friendly name for the overall site (e.g. "Farm North Dam"). This is just a label for your reference and does not affect functionality.
  2. Enter Your Credentials:
    • Device API Token: Paste your Smithtek.cloud device token.
    • Variable ID: Paste the ID of the single variable used to store the full schedule data.
    These fields may be hidden by default for safety. Click “🔒 Show Advanced” to reveal or edit them.
  3. Add and Configure Schedules:
    Click ➕ Add Schedule to create a new schedule block.
    For each schedule:
    • Output Name: Give the schedule a unique label (e.g. “Pump 1”, “Irrigation Zone A”). This is only for display and helps track which output each schedule represents.
    • Mode:
      • ON: Forces the output on at all times.
      • OFF: Forces the output off (no messages will pass through).
      • Auto Schedule: Uses the day and time settings to control output.
    • Start Time:
      • Enter the hour (0–23) and minute (0–59) in 24-hour clock format.
    • Run Time:
      • Enter the duration in hours and minutes that the output should remain ON.
    • Days:
      • Select any combination of Mon–Sun for when the schedule is active.
  4. Controls:
    • Click ➖ to minimize a schedule section.
    • Click 🗑️ to delete a schedule.
    • You can add up to 24 schedules in total.
  5. Saving: Click 💾 Save All to upload the full schedule to Smithtek.cloud. The config will be stored in a single variable.
SmithTek format
The scheduler node in Node-RED will fetch this data based on the interval you define in the node configuration (between 10 and 60 seconds). The PassPort will act accordingly even if the network goes offline, thanks to its built-in real-time clock (RTC) and cached schedule logic.
Functionality
  • Fetches and applies live schedule data from Smithtek.cloud
  • Supports 24 independent outputs
  • Modes: ON, OFF, Auto Schedule
  • Time-based logic with 10 to 60 second polling
  • Built-in status display under node
  • Change-based messaging to reduce traffic
  • Compatible with RTC-equipped hardware
Copyright (c) 2025
www.smithtek.com.au
Licensed under the terms of the GPLv3
Acknowledgements
Special thanks to:
  • Nick O'Leary and Dave Conway-Jones for their invaluable contributions to the Node-RED community
Contact: [email protected]
Website: www.smithtek.com.au
Version: 1.8.3
Updated 1 year ago
License: gplv3
6 in the last week
  • smithtek-nodered-schedule
  • scheduler
  • smithtek
  • iot
  • custom-node
