node-red-contrib-sm-sfan 1.0.1
A Node-RED collection of nodes to control Sequent Microsystems Smart Fan
npm install node-red-contrib-sm-sfan
This is the node-red node to control Sequent Microsystems Smart Fan Hat.
Clone or update the repository, follow the instrutions fron the first page.
In your node-red user directory, tipicaly ~/.node-red,
~$ cd ~/.node-red
Run the following command:
~/.node-red$ npm install ~/SmartFan-rpi/node-red-contrib-sm-sfan
In order to see the node in the palette and use-it you need to restart node-red. If you run node-red as a service:
~$ node-red-stop
~$ node-red-start
After install and restart the node-red you will see on the node palete, under Sequent Microsystems category one new node:
SFAN Power node
This node provides a connection to an Sequent Microsystems Smart Fan card. The card stack level can be set in the node dialog box or dynamically through msg.stack `. You can set the power from 0% to 100% thru msg.payload controling fan speed.
Important note
This node is using the I2C-bus package from @fivdi, you can visit his work on github here. The inspiration for this node came from @nielsnl68 work with node-red-contrib-i2c.Thank both for the great job.
Version: 1.0.1
Updated 5 years, 4 months ago
1 in the last week
  • SFAN Power
  • node-red-contrib
  • i2c
  • industrial
  • home
  • cooling
  • fan
