node-red-contrib-sm-ioplus 1.0.3
A Node-RED collection of nodes to control Sequent Microsystems Home Automation Card
npm install node-red-contrib-sm-ioplus
The Node-RED nodes for the Home Automation card
Command line installation
For first time installation, clone the repository:
~$ git clone https://github.com/SequentMicrosystems/ioplus-rpi.git
If you already cloned the repository, update to the latest version:
$ cd /ioplus-rpi/
~/ioplus-rpi$ git pull
Install the Node-RED nodes:
$ cd /.node-red
/.node-red$ npm install /ioplus-rpi/node-red-contrib-sm-ioplus
Restart the Node-RED service
~$ node-red-stop
~$ node-red-start
Node-RED installation
On the Node-RED home screen click on the Menu icon on the top toolbar right corner: menu
then "Manage Palette": manage
then "Install" tab: install
Search for "ioplus" and click "Install" again: search
Sequent Microsystems nodes for the Home Automation card will be displayed on the Node-RED palette
IOPLUS RELAY
This node controls the relays of the card. Set the "relay" parameter to [1..8] to control one relay, or set it to 0 for all relays. The card stack level and relay number can be set in the node dialog box or dynamically through msg.stack and msg.relay. The payload of the input message contains the state of one relay or an eight bit number with the state of all 8 relays.
IOPLUS 0-10V out
This node controls one 0-10V output channel. The card stack level and channel number can be set in the node dialog box or dynamically through msg.stack and msg.channel. The value in volts is set dynamically as a number between 0..10 through msg.payload.
IOPLUS ADC in
This node reads one analog input channel. The card stack level and channel number can be set in the node dialog box or dynamically through msg.stack and msg.channel. Reading is triggered by the message input. The output can be found in the output message payload as a number representing the voltage.
IOPLUS OPT cnt
This node reads the optically coupled input counter and sets the counting edges for one channel. The card stack level and channel number can be set in the node dialog box or dynamically through msg.stack and msg.channel. Rising and/or falling edge counting can be enabled/diabled from the node dialog screen. Edge settings are sent to the card when the node is deployed, when the flow starts or a different channel is selected through msg.channel. Reading is triggered by the message input. The output can be found in the output message payload as a number.
IOPLUS OPT in
This node reads the state of one optically coupled input channel. The card stack level and channel number can be set in the node dialog box or dynamically through msg.stack and msg.channel. Reading is triggered by the message input. The output can be found in the output message payload as a boolean value.
IOPLUS OD out
This node controls one open drain output channel. The card stack level and channel number can be set in the node dialog box or dynamically through msg.stack and msg.channel. The value is set dynamically as a number between 0..100%through msg.payload.
Credits
This node is using the I2C-bus package from @fivdi. The inspiration for this node came from @nielsnl68 work with node-red-contrib-i2c. We thank them for the great job.
Version: 1.0.3
Updated 3 years, 4 months ago
13 in the last week
  • IOPLUS RELAY
  • IOPLUS 0-10V out
  • IOPLUS OPT cnt
  • IOPLUS OPT in
  • IOPLUS OD out
  • IOPLUS ADC in
  • node-red-contrib
  • i2c
  • industrial
  • home
  • automation
  • 0-10V
  • open-drain
  • relay
  • analog
