node-red-contrib-sm-bas 1.0.1
A Node-RED collection of nodes to control Sequent Microsystems Building Automation Card
npm install node-red-contrib-sm-bas
This is the node-red node to control Sequent Microsystems Building Automation Stackable Card for Raspberry Pi.
Manual Install
Clone or update the repository, follow the instrutions fron the first page.
In your node-red user directory, tipicaly ~/.node-red,
~$ cd ~/.node-red
Run the fallowing command:
~/.node-red$ npm install ~/megabas-rpi/node-red-contrib-sm-bas
In order to see the node in the palette and use-it you need to restart node-red. If you run node-red as a service:
~$ node-red-stop
~$ node-red-start
After install and restart the node-red you will see on the node palete, under Sequent Microsystems category 7 new nodes:
BAS triac
This node will turn on or off a triac. The card stack level and triac number can be set in the dialog screen or dynamicaly through msg.stack and msg.triac. The output of the triac can be set dynamically as a boolean using msg.payload.
BAS 0 10V in
This node reads one 0-10V input channel (Make sure the corresponding jumper is in the "0-10V" position in order for this read to be correct). The card stack level and channel number can be set in the node dialog box or dynamically through msg.stack and msg.channel. The read is triggered by the message input and output can be found in the output message payload as a number representing the voltage readings in volts.
BAS 0 10V out
This node controls one 0-10V output channel. The card stack level and channel number can be set in the node dialog box or dynamically through msg.stack and msg.channel. The value in volts is set dynamically as a number between 0..10 thru msg.payload.
BAS R 1K in
This node reads the 1K ohms thermistor input channel(Make sure the corresponding jumper is in the "1K" position in order for this read to be correct). The card stack level and channel number can be set in the node dialog box or dynamically through msg.stack and msg.channel. The read is triggered by the message input and output can be found in the output message payload as a number representing the resistance readings in kiloohms.
BAS R 10K in
This node reads the 10K ohms thermistor input channel(Make sure the corresponding jumper is in the "10K" position in order for this read to be correct). The card stack level and channel number can be set in the node dialog box or dynamically through msg.stack and msg.channel. The read is triggered by the message input and output can be found in the output message payload as a number representing the resistance readings in kiloohms.
BAS DC cnt
This node reads the dry contact input cunter for one particular channel and set the counting edges for that channel. The card stack level and dry contact inplut counter channel number can be set in the node dialog box or dynamically through msg.stack and msg.channel. The rising edge counting and/or falling edge counting can be enabled/diabled with coresponding check box in the node dialog. The edge settings are sent to the card every time you deply nthis node or the flow start or you select different channel for read through msg.channel. The read is triggered by the message input and output can be found in the output message payload.
BAS DC in
This node reads the dry contact input state for one particular channel(Make sure the corresponding jumper is in the "1K" position in order for this read to be correct). The card stack level and dry contact inplut channel number can be set in the node dialog box or dynamically through msg.stack and msg.channel. The read is triggered by the message input and output can be found in the output message payload as boolean.
Important note
This node is using the I2C-bus package from @fivdi, you can visit his work on github here. The inspiration for this node came from @nielsnl68 work with node-red-contrib-i2c.Thank both for the great job.
Version: 1.0.1
6 in the last week
  • BAS triac
  • BAS 0-10V in
  • BAS 0-10V out
  • BAS R 1K in
  • BAS R 10K in
  • BAS DC cnt
  • BAS DC in
  • node-red-contrib
  • i2c
  • industrial
  • building
  • automation
  • 0-10V
  • thermistor
  • AC
