node-red-contrib-sm-8relind 1.0.3
A Node-RED node to control Sequent Microsystems 8Relay board
npm install node-red-contrib-sm-8relind
This is the node-red node to control Sequent Microsystems 8-RELAYS Stackable Card for Raspberry Pi.
Manual Install
Clone or update the repository, follow the instrutions fron the first page.
In your node-red user directory, tipicaly ~/.node-red,
~$ cd ~/.node-red
Run the following command:
~/.node-red$ npm install ~/8relind-rpi/node-red-contrib-sm-8relind
In order to see the node in the palette and use-it you need to restart node-red. If you run node-red as a service:
~$ node-red-stop
~& node-red-start
After install and restart the node-red you will see on the node palete, under Sequent Microsystems category the "8relind" and "8relindrd" nodes.
8relind node
This node will turn on or off a relay or all relays as a 8 bits bitmap. The card stack level and relay number can be set in the dialog screen or dinamicaly thru msg.stack and msg.relay. The output of one relay or all 8 relays if you set the the relay number to 0, can be set dynamically using msg.payload.
8relindrd node
Thi node will read one relay state or all relays states as a 8 bits bitmap. The card stack level and relay number can be set in the dialog screen or dinamicaly thru msg.stack and msg.relay and the state is output as msg.payload .If you set the relay number to 0 the node will output the state of all relays.
Important note
This node is using the I2C-bus package from @fivdi, you can visit his work on github here. The inspiration for this node came from @nielsnl68 work with node-red-contrib-i2c.Thank both for the great job.
Version: 1.0.3
Updated 5 years, 6 months ago
2 in the last week
  • 8relind
  • 8relindrd
  • node-red-contrib
  • i2c
  • relay
